CCC rating for Granite Ridge
dumboat2
Anyone know the CCC rating for a 2003 Jayco Granite Ridge?
9 REPLIES 9
golfknut
The sticker was on the backside of the cabinet door over the kitchen sink.
2018 Newmar Canyon Star 3513
dumboat2
Golfknut, where did you find the sticker?
dumboat2
That is what I needed, thanks. Jerry
golfknut
We have an '05 3100SS.
The sticker on ours shows a UVW of 12,451 lbs.
And a GCC of 1,598 lbs.
Minus full fresh water, LP gas, and 4 adults the resultant CCC is calculated to be 544 lbs.
Mich_F
The Ford van under that motor home was rated for 14,050#. I'd guess the vehicle weighs around 11- 12,000#, so I imagine you're somewhere around 2,000 - 3000# CCC. The only way to know for sure is to weigh the unit.
2014 Itasca Spirit 31K Class C
2016 Mazda CX5 on Acme tow dolly- 4 trips ~ 5,800 mi
Now 2017 RWD F150 with a drive shaft disconnect
dumboat2
It is the 3100 ss, so31 feet. No sticker, already looked. Archives gives the GVWR only. Even got in contact with Jayco and they never responded.
GrumpyandGrandm
There should be a sticker on the door under the kitchen sink or in one of the cabinets.
Grandma in front of her retirement home..
She lets Grumpy drive!!
triple602
Check Jayco site under Archive
Mich_F
It might help people help you, if you mentioned what size MH you're asking about.
