Ceiling Lights
Two_Hands
My coach has lights flush mounted in the vinyl ceiling. One is out. A tech told me that they pull down for bulb/led replacement. I’ve tried and tried and can’t move this thing. Any suggestions?
2015 Fleetwood Excursion 33D
2016 Grand Cherokee Limited
Retired Law Enforcement
U.S. Army 1965-1973/RVN 1968-'69
I am the frequent recipient of "Get out of the way old man!"
7 REPLIES 7
Ivylog
Even the ones that are spring mounted...pull down have lenses that twist off. Take a kitchen knife and push the ceiling fabric up to loosen its grip on the cover. Push up and turn CCW on the rim to loosen.
Upgraded with a 08 HR Navigator 45’...
MrWizard
Moderator
Moderator
ones we had in the Safari
the whole fixture pulled down
spring clamp was inside the cabinet bottom
took me forever to figure them out
I can explain it to you.
1997 F53 Bounder 36s
Dick_B
I don't know if it pulls down or twists but try the doubled over duct tape trick to get a grip.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
Two_Hands
Thanks rgat for the tip. I can’t pull the bulb/lense down or turn it. Can’t get any kind of grip.
ScottG
Pic = 1k words
Lwiddis
Pinch and pull?
rgatijnet1
Some are a twist type lock. Try twisting the cover CCW and see if it comes loose.
