Chassis Battery
E_Campbell
I have a Damon Astoria 3776 made in 2010. Can someone please tell me where the Chassis batteries are located? I called Damon and they can't find the specs for a vehicle made in 2010, (last sentence is not a joke).
8 REPLIES 8
E_Campbell
Thanks for all your help/suggestions. I got a call back from Damon and they suggested I look under the seats. Yes, I'm new to the RV world, thanks for the patience of it's more seasoned members to a question that shouldn't be so hard to answer.
DrewE
Effy wrote:
Why do I get the feeling this is a newbie post and run never to return?
And if it is...people have presumably helped a newbie to find their chassis batteries and hopefully help solve whatever larger problem they were having (if any). Future newbies might also be helped without any of us ever knowing it because they searched for the same information, and found it. None of that sounds terrible to me.
Effy
2013 ACE 29.2
Effy
It's a DP on a Freightliner.
Have you looked in all your bins? I can't imagine a battery is hard to find.
A quick google search shows a lot of the same units with pics of the bins and batteries.
Check this one:
CLICK
2013 ACE 29.2
wa8yxm
The Chassis battery is positionied by the chassis maker.
I know in 2005 Workhorse put the Chassis battery inboard (Behind) the passanger side front tire..Just ahead of and above the axle.. but I do not know if you have a "W" model (workhorse). or a Ford and I do not know where Ford hid the thing.
Effy
Did you call Thor?
2013 ACE 29.2
1492
Moderator
Moderator
Moved from Forum Technical Support
Trackrig
I believe it's built on a Freightliner chassis so I would look in rear two compartments on both sides. I would say on the left / driver's side, second compartment from the rear. There will probably be four house batteries in last rear left compartment and two chassis batteries in the second left compartment.
Bill
