Cheapest New Class A with cummins 8.9L ISL
zb39
We are looking for a DP. I do not want the ISB 6.7 regardless of HP rating. I want the ISL engine regardless of HP rating. Please advise. There is no replacement for displacement.
2017 Host mammoth, sold
49 states, 41 National Parks, 7 Provinces
2019 2 door Rubicon 6 spd.
2019 Berkshire XLT 45B
2022 Host Cascade
2021 Ram 5500 Air ride
11 REPLIES 11
dubdub07
The Discovery after 2013 has the ISL. Anything with an ISL is going to be a medium end coach.
2013 Fleetwood Discovery 40G
TOADS: 12 Jeep JKUR Wrangler, 16 Cherokee Trailhawk, 15 Grand Cherokee, 13 RAM 1500 Longhorn (not a toad) American STEEL = American profits
RET USAF MSGT (26yrs) and still DoD ATC.
DW,DS,DD in the MH w/Westley the killer PUG!
tropical36
What size coach are we talking here?
Smaller is cheaper and lighter, so yes, a real rocket ship.
Hopefully it will have a large enough tranny to pull more than itself, when loaded and with other specs. that many don't bother to consider.
"We are often so caught up in our destination that we forget to appreciate the journey."
07 Revolution LE 40E_Spartan MM_06 400HP C9 CAT_Allison 3000.
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
1998 36ft. National Tropi-Cal Chevy Model 6350 (Sold)
Dale_Traveling
Why stop at an ISL? If you're willing to step back in time a late model Foretravel U320 is available for under $200K with an ISM rated for 500 HP.
2005 Foretravel U320
2006 Hurricane 31D built on a 2006 Ford F53
Smitty77
Cheapest, usually delivers what your paying for...
If you want an ISL, pick your budget level, and drop year to buy the highest quality coach that remains within your budget.
IMO (And you can keep the $.02 if you don't agree:)!), it's better to have a higher quality built coach that is used, then a new lower quality built coach... (And quality is both build, components, and materials.. One tip, since you are say ISL let's pretend it's a 40'. Compare the weights of 'entry level rear radiator 40' units, with higher up the food chain side radiator units'... You will find that entry level quality coaches, weight less, then higher quality coaches. That added weight, comes from many areas ob better build materials, components, design, chassis, etc.
Happy hunting,
Smitty
fyrflie
So, what is the cheapest new class a with the ISL motor.
Is it the Discovery?
ScottG
I'm going suggest you revisit your needs and priorities. Decide what things you need in an RV. Then decide on size and budget.
That will give you a range of MH's that fit you.
And don't worry so much about eng size - the above will dictate that part to a large degree.
And there's no more wrong a cliche than the "no replacement for displacement". The replacement is technology and modern eng design. The smallest ISB puts out more power and torque than many OTR trucks of days past that had MUCH bigger engines.
univmd
http://www.mhsrv.com/2018-fleetwood-discovery-lxe-44h-bath-amp-1-2-450hp-tag-w-aqua-hot-u-dinette-ne...
2008 Gulfstream Tourmaster
2011 Honda CRV
Blue Ox Baseplate & Socket Wiring
Blue Ox Alladin Tow Bar
US Gear Unified Tow Brake
timjet
You're not likely to find a ISL in a smaller rig no matter how much you want to pay. Besides whats wrong with an ISB, I had two in my boat?
Tampa Bay
'07 American Tradition Cummins ISL
'14 Honda CRV
azdryheat
You want the cheapest? You get what you pay for and may be very sorry going with the cheapest.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
Ivylog
660 ftlbs torque
1050 ftlbs torque
1200 ftlbs torque
OP, I'm confused with a 2018 RAM 5500 ordered
Upgraded with a 08 HR Navigator 45โ€™...
wolfe10
Cummins ISB 6.7 liter
Cummins ISC 8.3 liter
Cummins ISL 8.9 liter
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
