I have a blown tail lt and clearance lt fuse but I can't find the fuse and what amp it is.Its on a 2006 fleetwood south wind 37c.I looked under the dash but there is no diagram just a fuse block and fuses. what amp is it?
Mine are on top of the dash in front of the steering wheel under a false lid held on by Velcro. I pulled all my fuses and replaced them with the ones that light up when they go bad. Not that expensive and WOW is it nice to open that fuse box and see the bad fuse lit up.
Chip 06 SurfSide 30ft class A 2 slides Ford V10 chassis 04 Chevy Astro van toad
Thanks Ive been under that dash an pulled every fuse out and looked at them, they looked ok so i put them back. Im getting to old for this ---t. what amp is the fuse? for the clearance and tail lights?
If it's a Ford F-53 chassic, the fuse block is on the left side of the steering wheel. You'll have to pull out every fuse and check it with an OHM meter to find the the bad one. Good Luck.
