Coach battery not holding charge
was_butnotnow
I have a mew to me 05 Monaco Cayman 36 DPQ
Replaced all the house and coach batteries and added 600 W solar.
The Solar controller has a 2 A trickle charge for the coach batteries. It is putting 2 A into the coach bats.
But even with the battery switch OFF they won't hold a charge. Goes to like 8 V but with the power boost can start the MH.
Should the 2 A charger keep the new coach batteries charged?
We are camp hosting so not starting the MH every day.
Now in a 05 Monaco Cayman DP 36 PDQ
Traveled many years in NuWa Hitchhiker 5th wheels.
Travel Journals and Adventures of people living this lifestyle
Hitchitch.com
Personal blog with our own travels. www.fulltime.hitchitch.com
17 REPLIES 17
Sam_Spade
was_butnotnow wrote:
Will look into getting a more powerful trickle charger for the coach batteries.
NO, NO, NO. The battery associated with the truck chassis upon which the RV was built should NOT lose any charge when the truck is turned OFF. Just like any other vehicle.
Once that battery is fully charged, it should sit there for MONTHS with little or no loss of charge.
Your story is confusing but it is entirely possible that your truck chassis batteries are not being charged EVER AT ALL even when the engine is running and you need to get the alternator fixed.
You should STOP SPENDING MONEY ON SOMETHING THAT YOU APPARENTLY DON'T UNDERSTAND.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
dougrainer
I know there is no charging of coach batteries from charger/inverter or shore power only when engine running. But do have that 2 A charge from the solar controller to the coach batteries.
By the way, they are new.
I can start the MH with the power boost turned on and charge the coach batteries up but then they don't hold that charge.
Will look into getting a more powerful trickle charger for the coach batteries. Anyone recommend a good full-time coach charger that I can run off of my house batteries or inverter. The inverter is always on when not on shore power do to a residential fridge.
You KEEP saying COACH Batteries. STOP! You are talking about the CHASSIS Batteries. Chassis are the ENGINE Batteries. COACH are the RV Batteries. Doug
Lwiddis
My “in storage” solar panel puts out 1.4 AHs at high noon and keeps my batteries full. Something is drawing current.
was_butnotnow
I just ordered Amp-L-Start
Hitchitch.com
FIRE_UP
Well,
You don't say how long it takes, from the time you shut down your engine, with a fully charged set of CHASSIS batteries, to drop to your lower voltage of 8 or so volts. Hours, minutes, what? The shorter the time frame, the stronger the short or draw there is on them. If it takes DAYS, well then, trying to find the culprit may be a bit harder. But, to simply provide a LARGER CHARGER to try and over power the draw, is not the answer here.
As has been suggested, get out your trusty volt ohm meter and start testing where tests are needed and results can be found. Once the culprit is found, your need for a LARGER battery charger will be greatly diminished. Will your CHASSIS batteries still need a charge while on shore power, sure they will but, only enough charge to overcome the parasitic draws that are standard in many of our coaches.
And that means, pickup either a Trik-L-Start or, it's bigger brother (recommended), the Amp-L-Start. The Trik-L-Start allows a maximum of 5 amps to be diverted to the chassis batteries if and when needed. The Amp-L-Start will allow a maximum of 15 amps to be routed to the chassis batteries, if and when needed. Even though I recommend the larger or, more amperage unit, it is not because of trying to overcome a potential high amp draw, it's because I'm one of those types that, if the 5A unit works, the 15A unit will work just that much better.
If you're not aware of how either one works, it's simple, whichever one you might choose, it ties into both sets of batteries and, when the CHASSIS batteries become even .5V lower than the HOUSE batteries, then which other one you chose, will jump into action and divert SOME of the amperage intended for the HOUSE batteries, and send it to the CHASSIS batteries. This is the most logical choice for these type situations. By the way, the Trik-L-Start or the other ones, is only powered up when shore power is connected and, your inverter/charger is charging the HOUSE batteries.
Scott
Scott and Karla
SDFD RETIRED
KI60ND
pianotuna
Nomad III
Nomad III
Hi,
You could use either an Amp-L-Start or possibly a Trik-L-Start.
However, I think I'd want to know what was drawing so much power.
Regards, Don
was_butnotnow
Hitchitch.com
theoldwizard1
Instead of "shooting in the dark", spend a few bucks and get yourself a digital multi meter with an amp clamp. Many to choose from on Amazon, such as Uni-T UT210E.
When searching for electric current "leakage" (Where is the power going ?), the othe method is to use your volt meter and probes to check the voltage drop across each fuse. All plug in fuses have 2 little spots on top. Just touch each spot with a probe. Ideally it should be ZERO if everything on thar circuit is turned off.
Sam_Spade
Your battery switch should be OFF ONLY when the RV is stored and not used. If the solar will be active during storage, the switch probably NEVER needs to be OFF.
If the batteries are going below 8 volts, you aren't using something right. Except in some kind of emergency situation they never should go below 10.
And yes the solar controller should KEEP the batteries charged at the 2 amp setting, when in storage, but it might not recover them from a deep discharge. It is also possible that it won't keep up with your "normal" use when occupied.
Since you are "hosting" aren't you plugged into shore power all the time ? If so, the solar is kind of redundant.
dougrainer
The coach batteries are the chassis batteries. My thought is if the kill switch is turned off no power should be used for anything on the chassis. The 4 new AGM house batteries are charged by a solar controller 600 W solar and Magnum 2000 w PSW charger/inverter. We are plugged into 50 A as a camp host site.
We do have a cell phone charging off the 12 v dash cig plug in and wondering why that works when the kill switch is shut down that controls the chassis power.
OK, now you have learned to call Chassis batteries what they are. They are not called Coach or house batteries. WHICH battery disconnect are you talking about and where is the disconnect located? Usually on most Brands of Motorhomes, the Dash charging ports are controlled by the Coach batteries because they realize that people will want to use them for their phones and such while camping. HOW long does it take for the chassis batteries to go to 8 volts? Usually on Monaco products if you turn the MANUAL battery switch OFF at the rear, that kills the chassis batteries. If you are just turning the entry door battery disconnect OFF that only kills the Coach batteries and it should NOT be OFF when using the RV. Doug
rgatijnet1
You bumped the mirror heat switch on and it is drawing more amps than your solar can replace.
pianotuna
Nomad III
Nomad III
Not enough information.
What solar charge controller do you have?
Regards, Don
FIRE_UP
was_butnotnow,
First off, your coach in in the '05 era. In many coaches, even and especially the diesel ones, the CHASSIS batteries were neglected from the shore power charging system. For some odd reason, many manufacturers deemed it not necessary for the chassis batteries to be charged while on shore power.
So, with all that being said, are you DEAD sure that your chassis batteries are being charged while on shore power? You state you have 600 watts of solar. Well, that's a ton of solar and while I'm not a solar expert, I'd just about guess that, that system is capable of around 20 amps of charging or more.
Your Magnum 2000 watt PSW Inverter/Charger will automatically adjust what it needs to send the house/Coach batteries when they have different amount of voltage present. The lower the voltage, the more the charger side of that magnum unit will put out. The higher voltage it sees, as in the house batteries are topped off, that charger will drop right down to a maintenance/float charge.
This is all in coordination with your roof solar. If it's supplying most of the charging for your house batteries, the Magnum will back down as, it sees no need to supply higher amperage for batteries that are already receiving it. Now, just because you have your chassis batteries switch shut off, that doesn't mean there isn't parasitic draws on on those. There will always be parasitic draws.
In this situation, I'd first get those chassis batteries load tested for prolonged load carrying capability. Then, it they check out fine, then make sure all connections are clean and tight and that also includes an often neglected one, the negative cable ends that normally attach to the frame. Those can get seriously corroded and rusted.
Once all the connections are clean and tight, then you need to determine IF, your Magnum Inverter/Charger is has been set up to send some amperage to the chassis batteries. For us Winnebago and Itasca owners, the same era coach as yours did not have any chassis battery charging from shore power. Winne started adding what's called the "Trik-L-Start" units in early '06 to remedy the dead chassis battery situation after even short term storage. But, any coach prior to that, had no means of charging the chassis batteries while on shore power.
So, this is why I suggest that you may NOT have any chassis battery charging unless an independent charger has been installed. I think I recall you mentioning a 2A unit. That's not much if the chassis batteries are used for purposes that running the engine etc. Things like the steps, slides, and other items. So, these are some things to check. Good luck.
Scott
Scott and Karla
SDFD RETIRED
KI60ND
was_butnotnow
Hitchitch.com
