Coach Battery
Cruisineasy
For some reason my coach battery will not charge when the engine is running. It used to. I have checked all of the fuses and all looks good. It will charge with the gen. or plugged into shore power. What else should I check???
It's a 2011 Jayco Greyhawk.
14 REPLIES 14
pnichols
I would replace your RV's battery charging solenoid with what ron.dittmer showed in his upper photo - but a much better version.
This approach will eliminate any voltage drop from "diode type" interconnect devices, such as is shown (I think) in ron.dittmer's lower photo. You always want the full alternator output voltage being applied to your battery terminals - not anything less. Here's a better version of the stock solenoid that comes in so many RVs. It even has a silver alloy contact option to stop corrosion of it's contacts ... and it's what I installed in our MH after the stock solenoid failed in a couple of years such that my coach batteries were not getting charged from the alternator:
http://shopping.murcal.com/Catalog/Bear-DC-Contactor-Family/114-1211-020;jsessionid=0a010c471f43e3c1...
2005 E450 Itasca 24V Class C
Cruisineasy
Thank you. It works..
tenbear
Cruisineasy wrote:
ron.dittmer
The image would not show.
It said, * image not shown due to your preference setting *
Go to "My Forums", then "My Preferences".
Scroll down to "General Preferences".
Check the box at "Show images that are part of posts".
You may have to sign in at some point.
2010 Subaru Impreza Sedan
burlmart
you may have a b.i.r.d. device that un-isolates both batts whenever 1) shore or genset are charging, or 2) when the alternator is charging. it may have failed or maybe one of its 5 or so connectors came loose.
2005 Trail Lite 213 B-Plus w/ 6.0 Chevy
Cruisineasy
ron.dittmer
pianotuna
Nomad III
Nomad III
Hi,
Generally the diode type ought to be avoided as they have a voltage drop of 0.7.
I used a relay type.
Regards, Don
ron_dittmer
I agree that the issue is likely the isolator. They look like one of these.
This is the cheaper mechanical type most commonly installed because they cost around $15-$20
This type is more reliable but not very common because of the cost around $50.
Unfortunately they can be mounted most anywhere in the rig, but the popular location is under the hood near the alternator.
Our first motor home had a Toyota chassis and the cheaper mechanical isolator which burned up and almost damaged an adjacent wire harness, just melting the black wire jacket alone. I replaced it with the better type which never gave me trouble over 15 years and I sold the rig with it working. You can see the better blue one in this picture in the lower-right area.
pianotuna
Nomad III
Nomad III
Hi,
The oem Ford relay lives underneath the chassis battery in my E-450. The contacts burned so I upgraded when I replaced it. I also replaced the 60 amp fuse with a 50 amp auto resetting circuit breaker.
Regards, Don
Bobbo
On mine, it is in an electrical compartment at the back of the storage bay right behind the entry steps.
Yours may be anywhere. Follow the hot wire from the coach battery, it will go fairly directly to that relay.
Bobbo and Lin
DrewE
The isolator can be mounted most anywhere that Jayco thought was appropriate. As an example, on my Coachmen (which, of course, could be entirely different), the isolator solenoid is mounted next to the coach battery under the entry steps, along with the main coach battery fuse and a little bus bar with connections for the converter, the main DC distribution panel (via the battery disconnect switch), etc.
I gather that not infrequently the isolator is mounted somewhere under the hood.
If you have an emergency start switch, pressing it causes the isolator system to temporarily un-isolate the two batteries. If you have someone press and release it you might be able to locate the isolator by listening for a relay/solenoid clicking on and off.
Cruisineasy
Yes Ford. E450 chassis
pianotuna
Nomad III
Nomad III
Hi,
The isolator may be a relay or a diode. Is it a Ford Chassis?
Regards, Don
Cruisineasy
Where do I find this battery isolator??
DrewE
Sounds as though your battery isolator is permanently isolating; troubleshoot that circuit. Often it's basically a solenoid (as in a heavy-duty relay) which is switched in at the appropriate times. The problem could be this solenoid unit itself, or the control wire/logic to turn it on, or a fuse in the line, or a connection at either end...
Sometimes the isolator is not a solenoid but a heavy-duty diode device. Similar troubleshooting applies, though some of the specific details are a bit different.
