Coach Power Switch
S_Gillis
Beaver 2005 coach with switch on entrance stopped working. Would love any suggestions on what is likely cause; solenoid / fuse / or switch?
Batteries are charged, coach is parked until spring.
Thanks in advance from Steph now in small town in British Columbia.
Sorry switch is for Coach Power
3 REPLIES 3
enblethen
Dead battery not powering the switch to energize battery disconnect would be first to check.
Bad battery disconnect relay.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
cavie
Again, is Coach power 12 volt or 120 volt.? Are you referring to the Battery disconnect switch at the front door of the MH? (sometimes called a Salesman switch by newbies) It is a low amperage switch controlling a high amperage relay. Just like the starter on your car.
The word POWER can mean 120 volt AC or it can mean 12 volt DC. Two different systems.
Disconnect switch can mean 12 volt disconnect switch or 120 volt disconnect switch.
Not picking on you. "What we have here is a failure to communicate".
a problem in a forum world.
2011 Keystone Sprinter 323BHS. Retired Master Electrician. Retired Building Inspector.
All Motor Homes are RV's. All RV's are not Motor Homes.
cavie
need better description. What is coach power switch??? 120 volt Main breaker??? Or 12 volt battery disconnect? Sounds like battery disconnect.
