coach water pump
rdenkert
I installed a new pump in coach and can not get it to pump water. If I hook batt directly to pump the pump runs. On the interior sw it cycles for just a second and no water out of faucet. As long as I cycle interior sw it will cycle for just a second but no water.
2 REPLIES 2
Old-Biscuit
Do you have more than 1 switch to turn water pump ON/OFF?
If so...pump controller is your issue.
ksg5000
Did you double check and make sure you turned the valves in the proper position so that water can flow?
Kevin
