โMay-03-2018 05:35 PM
โMay-04-2018 12:58 PM
โMay-04-2018 12:27 PM
MrWizard wrote:
Suspension is also a factor
Just because one coach has gvw that matches the gaw does not mean the op Winnie is built the same way
Max gvw is figured is based on all factors involved
Braking ability suspension weight capacity etc..
โMay-04-2018 11:57 AM
โMay-04-2018 11:08 AM
โMay-04-2018 10:30 AM
โMay-04-2018 05:47 AM
FIRE UP wrote:
The axles have their limits but, shouldn't the GAWR of the rear and GAWR of the front add up to the GVWR? If I'm not mistaken, they do on our coach. Our coach is an '04 Itasca Horizon 36GD with the CAT C-7 330HP. The rear axle is rated at 17,500 lbs. and the front is rated at 10,410 lbs. The GVWR on my coach is, 27,910 lbs. and says so on the drivers tag on the wall.
Scott
โMay-04-2018 04:36 AM
โMay-04-2018 04:09 AM
โMay-04-2018 03:32 AM
โMay-03-2018 10:57 PM
wolfe10 wrote:
Correct.
Axles have their weight limits.
But, the GVWR may be based on other factors such as brakes, transmission, etc.
Both numbers are important.
โMay-03-2018 05:48 PM
โMay-03-2018 05:41 PM
โMay-03-2018 05:38 PM
