Mar-25-2014 08:23 AM
Mar-27-2014 08:35 AM
Canadian Rainbirds wrote:
Last year I replaced 4 12V group 24 marine/rv "deep cycle" batteries with 4 6V GCs. The difference has been outstanding. I would never go back.
Same foot print, need more headroom.
Mar-27-2014 07:45 AM
pianotuna wrote:
Hi,
If treated with care these will last 20 years. Surrette 2 volt. You may find that the rv has to be redesigned to use them. Please be prepared for "sticker shock".wny_pat wrote:
Inquiring minds want to know about batteries that will last longer that the coach!!! Mine is twenty years old and on its third set.
Mar-27-2014 12:02 AM
Mar-26-2014 10:44 PM
Mar-26-2014 09:59 PM
Mar-26-2014 09:26 PM
Mar-26-2014 09:16 PM
Mar-26-2014 09:23 AM
tiredkid wrote:Inquiring minds want to know about batteries that will last longer that the coach!!! Mine is twenty years old and on its third set.topflite51 wrote:tiredkid wrote:Give it a rest tiredkid, the THE OLD WIVES CLUB MEMBERS around here support 6 Volt batteries. No if's, and's or but's about it. 😛philandmargo wrote:
I have a 2000 Tiffin Zephyr. It has 4 deep cycle 12 volt batteries that power the coach. The batteries need to be replaced. I have heard that using 6 volt batteries is a more efficient and economic system. Can my system be converted? If so, how would I proceed? Thanks, Phil
Purchase four of these; Chrome Battery 12 Volt 110AH Deep Cycle
same size as a 27 series but they are AGM,these will last longer than the MH and u never fill them etc
cost about $900.you will Need 8 6 volts to do same job and even the cheap acid filled ones will cost you at least $800 plus all the work to convert
not interested in that club.Guy asked if he should stick to 4 good 12,s and same wiring and the correct answer is yes. if it aint broke don't try and fix it. especially with the quality of 12Volts available today of which were not available when you formed the old wives club.
Mar-26-2014 08:44 AM
Mar-26-2014 08:09 AM
Mar-26-2014 05:54 AM
Mar-25-2014 09:59 PM
tiredkid wrote:You are comparing apples to oranges. Not too many folks have 215 amp hour (at the 20 hour rate) 12 volt batteries installed.OnaQuest wrote:tiredkid wrote:OnaQuest wrote:BSDP Don wrote:I understand that we are all just voicing our opinion, but that opinion should have some basis of fact.
"philandmargo...."wildtoad" and "tiredkid" have the best answer. Even though four 6 volt batteries are typically what are now used by most, the 12 volts are fine if they served you well. Since you have to buy batteries anyhow, the cost of batteries will be a wash, but with the price of copper cable, you could spend quite a bit of money on new cables.
Seems to me that one could re-use the interconnecting cables from the four parallel 12V batteries to interconnect the four series/parallel 6V batteries AND HAVE TWO CABLES LEFT OVER... Where's the big investment in new copper cables?
Because he needs 8 six volt batterys to make the same power as 4 12 volts(approx.)
Sorry, Not true.
ok explain your opinion. mine is I see 4 12V batterys at 215amp X4 = 860 and 8 6 volts at 225 per pair = 900 so pretty close?
I do know for sure your theory of Four 6 volts will = four 12 volts is wrong
Mar-25-2014 09:24 PM
Sorry, Not true.
Mar-25-2014 09:12 PM
