โMar-21-2014 07:21 AM
โMar-24-2014 06:36 PM
John S. wrote:RayChez wrote:wny_pat wrote:
8 straight hours of driving a P-30 is enough to cure anyone from enjoying driving one, while 8 straight hours in my Foretravel (no air) is a piece of cake. I'll bet 8 hours of driving the Country Coach is too!
Eight straight hours of driving is hard, does not matter whether you are driving a Prevost, Newell or a Foretravel. Lets be realistic!
I drive 8 hours all the time and many times it is 10 to 12. It is no different than what I do on a work day by working 10 plus hours. I do take a break every 3 hours in the beginning and every two hours after 6 but I will say that my Foretravel drives great and I love my solid axle up front. In fact many of my provost buddies drive longer than i do but they seem to want too. I can cross country in a bit over 4 days and that is not pushing but it is long hours in the seat. The Foretravel makes that possible and I have driven Country Coach units and they are very similar.
โMar-24-2014 06:21 PM
โMar-24-2014 10:35 AM
wolfe10 wrote:
All air bag suspensions on solid axles already have a Panhard rod.
Think of air bags as a marshmallow-- they have zero side to side movement control. They only support weight. So they HAVE to be located fore and aft and side to side.
โMar-24-2014 09:45 AM
Sully2 wrote:
"As far as fibers sticking out, that will not happen on a CC because CC did not use filon for wall construction. Filon is used on cheaper coaches and you can have fibers raise up and get mini cracks in it."
Absolutely 100% correct!
โMar-24-2014 09:36 AM
โMar-24-2014 09:32 AM
Sully2 wrote:I worked on many composite structures at Sikorsky A/C over the years. One test we used to do was to leave these structures outside for many years to see what happened to the surfaces. These were all woven fiber glass, Kevlar and graphite with various epoxy resins and not painted or the paint had worn off with time. You could see and feel the fibers where the resin eroded away after 10 years. We also tested in a hot wet chamber to see the effect of temp and humidity. Based on these tests the mechanical properties had to be lowered. Having said all that I don't think that Mike will have and thing to worry about as long as the MH was painted and protected over the years with wax. Surface cracking is another story. Until MH Mfg's start making the sidewalls and roof from prepreg (woven matl's that are preimpregnated with resin) surface cracking will continue to be a problem.RayChez wrote:
Check the fiberglass real close. I have seen many with the fibers sticking out, also hairline cracks on the fiberglass. Other then that it is a diesel pusher which is hands down better then any gas coach. The handling will be like day and night in difference. The air ride is amazing and you will never go back to a gas coach.
But check it real close once they get past ten years. I don't care if it is a Prevost. A coach is only as good as the previous owner on how he/she maintain it. Lot of good used coaches, but there are also some dogs out there.
We are talking Country Coach Ray...not COACHMAN!,,,,geeze
โMar-24-2014 09:25 AM
โMar-24-2014 08:57 AM
โMar-23-2014 08:14 PM
โMar-23-2014 08:04 PM
dons2346 wrote:mike brez wrote:
........... 2002 was the first year for total body paint and clear coat. The clear coat will only stick to paint faithfully. 2000 and 2001 coaches suffered from the clear coat peeling on the radius where the roof curves to over lap the walls.
So I am guessing the 99 Allure I intend to look at will just have fiberglass gel coated walls?
Not totally true. The '02s that are of the tan or cream color are not painted. Only the graphics are painted on and then the entire coach is clear coated. It should be noted that any year is subject to clear coat peeling on the roof radius, not just the early ones.
There was a guy some years ago, about '03 or '04, that was taking CC to court for false advertizing about the "full body paint" issue. His coach was the tan gel coat with clear coat over it. Country Coach was saying that they consider clear coat to be paint. I have no idea what happened.
โMar-23-2014 07:28 PM
โMar-23-2014 04:23 PM
โMar-23-2014 03:43 PM
โMar-23-2014 03:26 PM
