Day/Night Shades problem raising
Matt_NY
First of all, I do not believe it is a "string"problem...
We have a problem raising the Night part of our day/night shades. This has been an issue since we bought the Motorhome (used).
The "day" shades go up and down nicely, the night shades go down ok, but do not stay "pleated" as they go up! We are constantly having to manually "fix" many of the pleats to make it go up.
By fixing, I mean pulling them from both sides to straightened them.
They are Day/Night shades. The "Day" shades are a soft cloth (semi-transparent) and the "Night" shades are a darker, paper-like material.
Anyone have this issue? And can anyone give me any suggestions? I hate to buy new ones as they are not cheap.
Thank you in advance,
Matt
17 REPLIES 17
Tinstar
toolttime wrote:
I had to change strings on 2 of them in our old coach.Not a nice job to do.
I like doing my own work but it's certainly not something that you would want to tackle if you don't have much patients. The puzzle of which string goes where isn't too difficult since I made a diagram with different map colors for each string. I use a large needle to string the cord down through the blinds and I do it with them almost completely folded. The tedious part is sliding the center bar back in track without pinching the strings. Keeping a slight tension on the strings while the bar is slid back into place is the only way that keeps it from being too frustrating for me.
:CNever pass up a chance to go somewhere:C
toolttime
2015 Thor Tuscany 45AT
Tinstar
My day/night shades are over 20 years old and they work perfectly. I'd make sure your strings are in good shape. If they are frayed or otherwise deteriorated it could cause a hard push-pull. I have restrung several of mine. I used the blind shade cord from Jo-Ann Fabrics. It did smooth out the workings of them. I think the main thing is too much tension on the cords.
Mine are six string blinds too. That might make a difference. I don't know much about those with fewer strings.
mike_brez
Matt
Best bet is to replace those old day/night shades, they never go up and down with ease, I went with Allen Roth roller shades from Lowes with the EZ-lift clutch, its so easy to raise and lower the blinds now, only need 2 fingers to do the job..
http://www.lowes.com/projects/decorate-and-entertain/window-shades-bg/project
Not to sure about that. My 17 year old day/night shades can go up or down with one finger but two is better to even the load. Sometimesi wonder if it's the cheap **** they are putting in newer rvs these days.
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
timmac
Matt
Tinstar
GGeorge wrote:
Can anyone tell me how to loosen the tension to make these shades go up and down easier?
Thanks in advance
G George
The tension is controlled with the bottom strings that come out the end of the bottom blind bar. Too much tension will cause a hard pull/push. Too little tension will cause the blind to fall or not hold in place.
Tinstar
prstlk wrote:
Tinstar wrote:
The starch has worked on mine. A couple of years ago, mine were in need of a good cleaning. After cleaning them, I sprayed them with starch and folded them tightly together. They are still holding the pleat and I would do it again as needed.
Curious, what method did you use to clean them? The shades have yet to recover from the alaska trip this summer.
Thanks
Sorry, I just saw your question. I took them down, opened them all the way. On the ones that were more narrow, I sprayed them down with Greased Lightning. Let them soak for an hour or so in the bathtub. Rinsed them in the shower. Sprayed them with the starch and set them in the sun to dry. On the wider ones, I lay them out on my bar, sprayed them HEAVY with the Greased Lightning and covered them with plastic to keep them from drying out. The next morning, I rinsed with a water hose then put them in the pool to really get the Greased Lightning out of them, sprayed them with the starch then sun dried them.
If your blinds are made of the paper type stuff, I wouldn't try this as they will probably come apart.
GGeorge
Thanks in advance
G George
GGeorge
Marietta, Ohio
2014 Coachmen Encounter
2010 Jeep Liberty
prstlk
cseidel wrote:
I soaked mine in oxycllean. Worked great.
How did you soak them ? Spray, dunk, washing machine please let us know and thanks in advance ?
2007 Keystone Challenger 5th wheel, Ford F350 Super Duty 6.7L Diesel, Short Bed, 2 dogs and the cat and rolling down the road full time since May 2014
prstlk
cseidel
prstlk
Thanks
imgoin4it
I never had to try it but that was recommended by winnebago in the early 2000 owners handbook.
Howard,Connie,& Bella,
One spoiled schnauzer
2007 Newmar KSDP
4dr Jeep Wrangler
Tinstar
