Dead batteries
Poppy2003
winter stored RV for 6 months, no shore power, now batteries are dead, can I jump start with my car battery?, my Generator also not starting, thank you.
Vijay
13 REPLIES 13
wa8yxm
Oh for 90 bucks Horrible Freight (Might even be cheaper) has a nice small 450 Amp Lithium battery
Click here to see it
And for 75 NAPA has a 1,000 amp lead acid (heavy) one
Again click here
Fully charge the battery
Go to the generator. the actual generator Find the RED lug with the 12 volt line hook the RED cable to it.
Hook the Black cable to any handy Generator FRAME part
Start the Generator
Leave the battery hooked up for at least 1 minute or till you hear the Transfer switch or the Generator load down as the Transfer switch engages.
Make sure the Generator breaker does not trip.. then unhook the battery
Wait a while
Try to start it
Oh you will likely need a new Chassis battery.. House batteries depends GC-2 MIGHT recover.. MARINE/deep cycle will need replacement.
dedmiston
Moderator
Moderator
You should be able to jump your generator too. Don't connect to the batteries though, connect to the gen itself. Pos to the pos input on the gen and neg to the gen's chassis. At least that's what I've done on my Onan.
2014 RAM 3500 Diesel 4x4 Dually long bed. B&W RVK3600 hitch โ€ข 2015 Crossroads Elevation Homestead Toy Hauler ("The Taj Mahauler") โ€ข <\br >Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
mfinnerty
If your Sunova is like my 2003, you won't be able to start the generator until you have a charge on the house batteries. I should also ask if you checked the house batteries disconnect switch. It should be on the left of the entry door. If the batteries are disconnected it will seem like they are dead.
Mike & Linda Finnerty with Finn & Rosco (Golden mix brothers)
Matt_Colie
Poppy,
As said, try to jump start it, but don't plan to idle the main engine long enough to recharge either the chassis or the house banks. Nothing good happens to an idling engine.
As soon as you can, start the APU (on board generator) and use that to charge the house bank. While that is happening, find out how to cross link the house to the main engine battery and use your existing converter/charger to charge that as well. Be ready, as dead as they may be, they may take a day to recover. They also may not recover. I have some dead AGMs in my shop right now that have not recovered. I have been trying for a while. It's a total **** shoot.
You will have to do the full diagnostic to know what you have to replace.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs (one dear dog is waiting for us at the bridge) going to see some dry places that have Geocaches in a coach made the year we married.
phillyg
Don't give up on your batteries. I've successfully brought mine back from near dead twice now. Since then, I keep them up with a small solar panel while in storage.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
Poppy2003
navigator2346 wrote:
Yes to the jump start. After you get the coach running, you might be able to start the generator after a few minutes. It would be best to get a stand alone battery charger and make an attempt to charge the batteries instead of trying to use te generator and on board charger. Your batteries could be toast
Thanks, will try that first, if not have to change all the batteries, keep it AGM, as Lithium is very expensive for a retired old man.
Vijay
Poppy2003
garym114 wrote:
probably not, use a 110v battery charger. This may not work because the batteries sat a long time with no charge, totally dead, may have to be replaced.
Next time move the negative cable from all batteries.
see my signature
Thanks, I'm a new RVer, bought it in last october and winterized and stored, shop never told me to disconnect - pole, I guess you live and learn, batteries are 4 years old. Planned a trip to all the National Parks this July on.
Vijay
Poppy2003
jdc1 wrote:
If it's a diesel, you'll need more than a car to jump start it.
no its gas, ford v10, 2003 Itasca sunova 30b, thanks,
Vijay
jdc1
valhalla360
Navigator
Navigator
Are they completely dead or just weak (turns over real slow)?
Also, what is the motor? A gas V10 probably. A big diesel...less likely.
If you have access to shore power, better to get a charger on it
If you do jump start, make sure the car engine is left running, so you don't kill the car battery. Also, if you get the MH engine running, operate under the assumption the battery won't restart it, so don't shut it off unless it's somewhere you can leave it.
Removing the battery terminal (or putting in a disconnect switch) is a good idea but doesn't help you now.
If you are lucky, the battery will be OK but plan on replacement.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
ArchHoagland
I'd put the jumper cables on and let it charge the starting battery for about 20 to 30 minutes before I try to start it.
Friend of mine just had the exact situation at his storage location, we let the car charge the battery and got it going.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
2000 LEXUS RX300 FWD 22MPG 4020 LBS
US Gear Brakes
navigator2346
garym114
see my signature
2000 Sea Breeze F53 V10 - CR-V Toad
Some RV batteries live a long and useful life, some are murdered.
Get a Digital Multimeter and Learn How to Use It
