Diesel engine problem
Gonzo42
I have a service engine light and an OBD code referencing the mass air sensor. So far the info I'm getting is that there is an intermittent sudden change in the sensor reading.
Trying to find a qualified mechanic in my area that knows this engine.
Does anyone have experience with this problem or have any ideas?
MOTHER SHIP Winnebago View 24H (2007 Dodge Sprinter 3500 Chassis, 2008 Body)3.0 L M-B Diesel V6 bought used with 24K miles. Toad: ROCKY the Flying Squirrel.
6 REPLIES 6
Gonzo42
Further information: I have been told I have to drive long distance on cruise control at 55-65 mph.
Finally I did a long enough drive. At about 125 miles on the trip meter, the Cat Conv Monitor set OK. I then proceeded direction to my Smog Tester and now I'm good to go.
Gonzo42
3 different OBD scanners show that the Cat Converter monitor (in the ECU) does not finish. Because of this, attempts at Smog Test will fail.
I'm told I have to drive a very long distance on cruise control at 55-65 mph for it to complete. I've done a 60 mile and a 100 mile drive but no luck so far.
Any suggestions?
Gonzo42
it appears that the problem has been identified: The intake tube at the front of the turbo was disconnected, due to sloppy work by a mechanic last year.
pauldub
I'd ask here Sprinter Forum
NMDriver
Just follow directions on the MAS spray can. Don't forget to spray the plug too. If you have a oiled air cleaner filter (K&N) get rid of it and use a dry filter.
5er/2500Duramax/18ftBoat
azdryheat
Probably just needs some cleaning inside the throttle body. Easily done. Spray available at any auto parts store.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
