Dirt ceiling
Moffittclan
We just bought this rig and the ceiling has the carpet type covering...around the air vents it is discolored. You can tell they tried to clean it (there is some kind of power that falls out as you rub the ceiling). Is there a preferred way to clean these types of ceilings? Do you just hire a carpet cleaner to come in and steam clean it?
23 year Active Duty Air Force
Waiting to retire (when I'm done having fun)
Empty Nesting it starting Summer 2016
2003 Damon Escaper 40' 3 slides (my first Class A)
330hp Cat 3126E
2014 Jeep JKU (toad)
20 REPLIES 20
wolfe10
The carpet is likely Ozite: http://www.ozite.com/products/commercial/marine/
http://www.ozite.com/dfiles/Marine-HullLiner_Headliner2014.pdf
Best cleaner we have found is fantastik scrubbing bubbles oxy power.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
Ozlander
Moffittclan wrote:
We just bought this rig and the ceiling has the carpet type covering...?
Weird....
Ozlander
06 Yukon XL
2001 Trail-Lite 7253
Moffittclan
donn0128 wrote:
If your handy, I think I would strip it off the hacker board. Which is probably 1/8 inch Luna, go buy some sheets of 1/8 inch refinished boards, cut and glue/screw it up. Finish with some quarter round on the edges.
I'm pretty handy...I usually buy a house, fix it up while living in it and sell it 3 or 4 years later (I'm in the military)...So although I wouldn't call myself an expert, I'm not scared to try...This might be a future project that will give it a really updated feel!
330hp Cat 3126E
donn0128
Moffittclan
donn0128 wrote:
Power or powder? If when rubbing the ceiling material you see stuff coming out, I would guess the foam backing is failing. Meaning, you best choice is likely a complete tear off and replace.
Oops, sorry...yes, I meant "powder". But it doesn't really seem like the foam backing is failing as it's still very solid...it's more like they tried to sprinkle on some kind of agent to clean it with and then didn't vacuum it out or something.
Slightly different topic (since you mentioned it), the wife would like to take it off and do something different but that seems like a HUGE job...I have no idea what's under it or what I would replace it with...
330hp Cat 3126E
donn0128
