Dodge Avco saga 1979 year model
shaneperch
I am getting a new carburetor for this motorhome. I replaced the wires and the spark plugs and repaired a wire going from the alternator to that regulator and it isn't stalling anymore. My questions are. is this engine an electric choke or mechanical? there is a wire that goes into a block that is right next to the carburetor that goes to that alternator wiring that I mentioned. What is that for? I am thinking of getting an Edelbrock replacement that is brand new. Any advice? I cleaned all the fuel lines and replaced the electric fuel pump and filters. also my Genset won't start and I have no ignition. thanks for the help.
3 REPLIES 3
timmac
I had a old 79 Dodge class c with a 440, it doesn't matter what the old carb had for choke just get a new one that has the electric choke and run a new wire if it does not have one, its a easy fix, you can tell a manual choke by a small linkage that goes from manifold to carb that has a metal sprail attached to linkage.
Yes that Edelbrock is a good carb.
gbopp
shaneperch
Here is the carburetor I am thinking about.. but not sure if my unit is electric choke and more thinking that it isn't but anyway is this a decent carb?
http://www.ebay.com/itm/New-Edelbrock-1406-Carburetor-600-CFM-With-Electric-Choke-/161588769845?hash=item259f70f435&vxp=mtr
