โMay-28-2015 07:05 AM
โMay-31-2015 04:03 PM
โMay-30-2015 08:41 PM
โMay-30-2015 03:42 PM
FeeLine wrote:
All good info guys, but I have a question, does anyone know of a good replacement lock? My lock has stuck a few times and I would like to replace it with a reliable lock before I get locked in or out.
โMay-30-2015 03:20 PM
โMay-29-2015 04:02 PM
โMay-29-2015 01:07 PM
โMay-29-2015 08:14 AM
Groover wrote:
I got stuck in mine a while back and I could feel the latch working when I pulled the handle. The problem was that one of the extra studs above and below the striker had had unscrewed itself with road vibrations and was interfering with the door frame. Fortunately, it had not gone very far and after using the fire escape I was able to pry the door frame out enough to get the door open and remove the stud.
โMay-29-2015 08:11 AM
โMay-28-2015 11:56 AM
Dutch_12078 wrote:rgatijnet1 wrote:
Sort of a known problem on a lot of RV doors that use the Trimark handle. The pot metal breaks inside and the latch must be drilled out to open the door. Many people ONLY use the dead bolt portion of the lock and do not use the other lock that controls the door handle.
If you have access to the inside of the RV by other means, the Trimark lock can be released without drilling.
โMay-28-2015 10:35 AM
โMay-28-2015 08:59 AM
mark734 wrote:
cant get door open
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
โMay-28-2015 08:58 AM
โMay-28-2015 08:45 AM
โMay-28-2015 07:07 AM
