DP air bag inflation question?
supercub
If you use the dump switch to dump your air......and don't use the jacks, such as when you store it, and don't put the jacks down. When you start the engine, do your airbags inflate ?? or do you have to hit the retract all button on the jacks, even though the jacks aren't down?
26 REPLIES 26
supercub
My question is............forget abut the jacks, they're not being used. I dump the air using the dump switch on the left hand panel.............then start the engine........shouldn't the air bags inflate? JACKS are UP.........haven't touched them........pretend I don't even have jacks LOL...........when you start, shouldn't the air bags inflate? Thanks
Brian
I did call Fleetwood and they said yes, they should inflate. I'm just looking for info to share with shop, they seem to think they shouldn't.....and I'm positive they use to. Just need to make sure I'm right before I go back to them. Thanks
Brian
Triker33
Best to park in storage with jacks down to take some weight off the tires.
Long term storage add 20% more air to the tires.
Larry Full Time Since 99
1999 34Q Discovery DP ISB 275HP 6 Speed Allison
VMSpc | Pressure Pro
14 Lincoln MKS EcoBoost Toad
Click here to see where I am
supercub
All good info so far, thanks
Brian
FIRE_UP
Roger that Brian,
I gave you specifics so that it might help you understand at least how the system partially operates. While basics may answer some questions, they most likely will not in your case, based on your type of system and, it's particulars in operation. So, when one person answers you and says, "All I have to do is, start up our engine and, it will start filling the bags", that's not the case in other systems.
Hope this helps some. Good luck.
Scott
Scott and Karla
SDFD RETIRED
KI60ND
supercub
Well, actually I was looking for GENERAL info regarding this....not to a specific make and model.........that's why I didn't mention it.........but in my 2004 Fleetwood Revolution 38B I have a Power Gear Auto control leveling system on a Freightliner Chassis.
Brian
FIRE_UP
supercub,
Yes, it would be nice if you'd put your coach/model/make/ etc. and, also the brand leveling system. You see, In all that, the make model of the leveling system is the most important. But, leveling systems differ between different makes of chassis's on coaches.
For instance, in our coach, an '04 Itasca Horizon, 36GD with the C-7 330HP CAT, we have the HWH 625 Computer Controlled Automatic Leveling system. That system has two styles of dumping the air from the bags. In the Automatic side of the operation, HWH takes care of the dumping and, when it comes time to air back up, HWH takes care of that when you hit the "Store" button. The jacks will begin to retract and, the air bags will begin to fill.
On the Manual side of the operation, it's pretty much the same thing with the only difference being that, manually lowered the jacks instead of HWH taking control.
Now, if you WANT to dump and, not lower the jacks, in the HWH system, you still have to turn the HWH system on but, just hit the dump valve button. And, what's most important here is, you cannot do anything without SETTING THE PARKING BRAKES! There is an interlock ground connection that is provided by setting the brakes.
So, to answer your original question, depending on WHO is the maker of your system, at least in the HWH 625 system, you must either push the "Store" button or, release the brakes, in order for the bags to start filling. At least that's the way I understand the HWH service manual and owners manual.
Scott
On edit: Apparently I was typing when you answered about your make and model. May I ask, what chassis?
Scott and Karla
SDFD RETIRED
KI60ND
supercub
Thanks Wild Bill.........I just looked at my profile, I have a 2004 Fleetwood Revolution 38B listed on it.
WILDEBILL308
Well if you had filled out your profile and had your coach info in your signature I could have given a better answer.
If I leave the dump valve open it will not fill the bags. If the dump valve is closed the bags will fill. Bags are separate from jacks.
Bill
2008 Newmar Mountain Aire
450 HP CUMMINS ISM
ALLISON 4000 MH TRANSMISSION
TOWING 2014 HONDA CRV With Blue Ox tow bar
A man who carries a cat by the tail learns something he can learn in no other way.
-Mark Twain
gemert
Ours inflate and go to travel mode as soon as I start the engine.
Jerry
Chief USN Retired
2003 Beaver Patriot Thunder C-12 505HP
2004 Dodge Ram 1500 4X4
Valkyriebush
Mine inflate after flicking the dump switch back once air tanks fill after starting the engine. Jacks position makes no difference up or down. Freightliner XC chassis.
Command Master Chief (AW) USN, (ret)
2003 Fleetwood Excursion 330 Turbo Cat 39D
2000 Jeep GC
2005 Big Ruckus (Rides Behind Jeep)
2003 VTX 1800
filadelfia
Supercub, My airbags inflate without hitting the all retract button.
Don 2005 HR Neptune
2006 Jeep Liberty toad
Phil___Stephie
On our Spartan chassis, once you start the engine the bags will inflate.leveling jacks are separate.
Phil & Stephanie Grey
"Partners In Life"
2016 Allegro 36LA
2007 Chevy HHR
Yorkies; Paisley Marie & Opie Taylor
