DP over heating
jurzbill
Travelling and after about 300 miles, check engine light went on. Pulled over. after about 5 minutes , temp went back to normal. Travelled another hour and it happened again, pulled over and temp went back to normal. Had road service come out, checked fluids, ok, hoses ok, belt ok. Just had thermostat replaced last June.
This happened several times during the next few hours. Would travel an hour or so and temp gauge went up, stopped and in sever minutes temps want back to normal.
Any suggestion.
2004 ksdp 39ft
toad:2014 Ford CMax
:W
FMCA F359471, Newmar Kountry Klub 17645
bill, linda cary grant, carley.
chance and chase are with us in spirit and travels with us where ever we go.
2 REPLIES 2
Rollnhome
Fan clutch. There is a 4amp fuse in a black box located in a compartment in the rear of the MH with the name ARENS on it pull that fuse and see if it runs cool. If so replace fan clutch.
2008 Discovery 40X towing a Jeep Grand Cherokee
keepingthelight
Actually with a Freightliner chassis, you have SANDWICHED cooling system. The CAC (Charge Air Cooler) is in front of the radiator and is where the vast majority of the dirt and debris is deposited.
Yes, you can clean it yourself. Access the top of the motor/fan shroud area-- from bedroom or closet. Use a garden hose/nozzle. If just dirt, that is all you will need. If there is any oil or grease holding the dirt, you will need a cleaner. Dawn, Simple Green Extreme (Aluminum friendly), etc will work.
Be sure to wear old clothes, it is a pain to clean around the fan blades, but the fan blades sling the dirt to the perimeter where it is hard to remove-- particularly the lower perimeter.
Flush until the effluent is clear.
Also make sure your blow by hose has been extended past the radiator to prevent oily mist from getting back into the radiator and intercooler.
This needs to be done once a year.
05 Tiffin Phaeton 40 QDH w/4 slides
CAT C7 350+ HP MP-8, Aero Muffler, AFE Filter
06 HHR LT Toad
Ready Brute Elite
