DPF Filter Clean
strudeau
Need to have my DPF Filter cleaned. How many have had it done, and what was the cost? Engine is a Cummins ISL 425 on a Spartan Chassis. (No DEF) System won’t do a
Regen, And is giving a constant HEST light. OBDII reader shows a SPN 3245 Aftertreatment 1 Exhaust Temperature 3 Code.
Scott
2019 American Coach Dream 45 A , Allison 4000, Freightliner Chassis
2017 Ford F-150 King Ranch, Toad, Air Force One Supplemental Braking
Retired LEO
2 REPLIES 2
sprintmod1
I have had my done twice. Cost has been about $800 if I remember correctly.
It is a DOC/DPF filters in that can. Check around, various companies have the cleaners that are required. Call around and check. Some of the large trucking companies with their own in house repair technicians have been buying and installing the cleaner machines. If you find someone who works where there is one, you might be able to get it done at a "discount".
The HEST light, when does it come on?? Is it on all the time or flash on and off ocasionally?? Mine would go on when braking hard and quickly and coming to a stop and putting the parking brake on. Found out that it is a warning light that the DOC/DPF are at a high tempature and they don't want you stopping to quickly around material that may catch fire at the exhaust pipe end.
If you take your DOC/DPF apart yourself, be very careful. Once we did ours the second time after it plugged after a few thousand miles, you may be needing injectors for that Cummins. And that gets expensive real quick as we were forced to replace all of them.
2010 American Coach Revolution 42w; carrying 2014 HD Electra Glide Limited and towing 2015 Chevy Silverado 2500HD.
Dirt's for racing and asphalt for getting there.
410 Sprint Car's rule!
PhilipB
Just had one cleaned in a Kenworth semi (Cummins ISX15) no DEF. It was $1200 ($950 Labor. The rest a few parts & tax). This was done at a Kenworth dealership.
2015 Ram 2500
[purple]2013 Raptor 310TS[/purple]
