Mar-20-2017 05:19 PM
Mar-21-2017 03:37 PM
Biggyniner wrote:T18skyguy wrote:
Here's the story on exhaust manifolds. We didn't have warping manifolds(or brake rotors) back in the 60's and 70's. The reason we have problems now, is that to save money, the manufacturers eliminated the nickle content from the metal, which really gave it it's strength. With the heat they stretch, warp, and break the bolts, most commonly the back right. The best permanent cure is headers. I went with Banks. Did the job myself. Yea it was a hard job, but your problems will be over for good. When you plane the manifold, it removes metal, and the manifold just runs that much hotter and warps again. Here's how you test a warped manifold. Take the manifold and put it on a perfectly level surface. Usually a supported piece of glass will work fine. Take a feeler gauge and measure the gap(warpage) all around the whole thing. If the gap is any larger than .01 inche, no gasket will seal it correctly, then you can try and plane it. But having been there done that, the Banks with it's 5/8 thick stainless flange is the best. Thorleys are good also, but never put cheap headers that have a flange less than 3/8. I wouldn't even do that myself. If you go with the Banks, save some money and skip the Ram Air part. It does nothing but make you feel good. If you have to drill out a broken bolt, they sell drill guides that keep it straight. However, you need to use a drill stop, because if you go too deep you get into the water jacket which is only 3/8 thick. Particularly on the back right. There are multiple threads on this issue if you search it. Good luck with it.
I looked at Banks, but they don't offer any headers for the 460 on the E350 platform, at least for my year. I'm assuming this is due to the tight space constraints. Thorley did have a ceramic coated set for a little over $800.00 ...
Mar-21-2017 01:02 PM
Mar-21-2017 12:29 PM
Mar-21-2017 11:36 AM
Mar-21-2017 11:33 AM
Mar-21-2017 09:25 AM
Mar-21-2017 07:22 AM
crasster wrote:
I will probably catch some "heat" for this but you could always try:
Blue Magic
If used right it's supposed to seal cracks and gaps and keep them sealed. MAY be better to use and see if it works before a huge job.
Mar-21-2017 06:51 AM
ernie1 wrote:
I had the same problem on my 1989 E350 Econolpne with a 460 engine. My problem was that one of the heads on the manifold bolts was sheared off and there was nothing but the stud left. I tried gripping the stud with a vise grip and, when I turned it, the stud broke again till it was just about even with the head. I then tried to drill the broken stud out but the clearance was way too tight. Soo, after spending about $1900 at the Ford stealership to have the intake manifold and head removed to drill out the stud I got my rv back with a big dent on the rear of the vehicle. Apparently the tech that was working on it backed into a lift and hoped I wouldn't notice it. I went back and complained to the Service manager who said they would repair the damage. When I went to pick up my vehicle, I noticed while traveling on the freeway that there was a lot of wind noise coming from the driver's door and it seemed loose. When I got home, I found out that someone loosened the striker pin thing on the door so that it would not close tightly. CAN'T IMAGINE HOW THAT COULD HAVE HAPPENED! Anyhow, good luck on repairing the manifold.
Mar-21-2017 06:21 AM
Mar-21-2017 04:30 AM
Mar-20-2017 07:38 PM
Mar-20-2017 06:45 PM
