โMar-28-2015 09:38 AM
โMar-28-2015 04:26 PM
โMar-28-2015 02:55 PM
j-d wrote:
We're in FL with a 31-ft C V10/4R100. E4OD means you probably have a V8/460 engine. Ford morphed the E4OD into the 4R100 with minimal changes when they went to V10 in 1997.
We run in OD which is Fourth Gear, Locked Torque Converter. At the slightest additional load, like an overpass on the interstate, it downshifts. When that series downshifts, it doesn't just unlock the Converter to produce a little more torque to the wheels. Instead, it drops to Third Gear, Locked Converter. Basically, goes to Passing Gear. That's quite a ruckus but how the transmission is designed.
It's most sensitive when on Cruise Control. If I see an upgrade, I can speed up by enough that the "sag" caused by the climb is no more than about 1-mph less than the cruise is set for. Otherwise it's gonna downshift.
In hilly country, like FL Panhandle, I leave it in OD but don't use cruise. It's less annoying to me to see a grade, speed up, let the speed sag, recover it on the downhill, repeat for the next grade.
Nature of the Beast, hope this helps.
โMar-28-2015 12:33 PM
โMar-28-2015 12:00 PM
โMar-28-2015 10:56 AM
โMar-28-2015 10:39 AM
โMar-28-2015 10:13 AM
