Sep-01-2017 05:36 AM
May-23-2018 04:52 PM
May-18-2018 05:02 AM
May-17-2018 07:17 PM
DrewE wrote:I had the same problem and could not find the leak anywhere. Pulled window and resealed, re caulked front cap, clearance lights and roof several times in a year and finally found a small seepage on the vertical seal of the front cap and sidewall. I put my wife's vacuum cleaner to blow mode and blew air in that area and saw water bubbles coming from 30 ft away in the rear channel that attaches the roof to the side wall. Water was running down that channel all the way to the front because my driveway was sloped forward. After sealing I added a piece of 3/4 in oak to the inside wall and secured the mirror with 4 lag screws.
Particularly if you were angled front down slightly, water might be able to leak in some distance back and travel forward before working its way down, depending somewhat on the exact roof edge construction. Water doesn't flow uphill as readily, of course.
Also check the clearance lights; they're a not infrequent source of angst.
May-17-2018 06:22 AM
May-17-2018 04:45 AM
jdavidsmi wrote:
Dutch 12078; I had not pulled the window out but, it's out now; there was a thin 1/8"x 1/2" rubber gasket around the window and in the corners it was hardly in contact with the fiberglass, the guy at our local RV shop had never seen this type of gasket. I got a roll of regular window sealant tape, I will put it back in tomorrow. Just don't have the stamina I did.
May-16-2018 07:37 PM
Richard: I don't know where a toggle bolt may be located?
DrewE: I have replace all the clearance lights with new ones and new gaskets. but that does not mean one is not leaking. I will re-pull them out and recheck, maybe recaulk the holes where the wires and screws go through.
I have also rechecked my ceiling and I don't see any stains or feel anything wet.
May-16-2018 04:44 PM
May-16-2018 03:43 PM
May-16-2018 01:33 PM
May-16-2018 12:35 PM
May-16-2018 10:48 AM
May-16-2018 07:52 AM
May-16-2018 05:55 AM
Sep-01-2017 10:41 AM
