โNov-14-2016 06:00 AM
โNov-15-2016 01:36 PM
โNov-15-2016 04:23 AM
โNov-14-2016 05:27 PM
โNov-14-2016 05:06 PM
โNov-14-2016 04:56 PM
joexsmoot wrote:Go to local parts store and tell them you want a conversion kit to R134, Cheap, This will be the ports you need to convert lines to take 134 gauges. You will need a flush kit and may have to break lines loose and replace o rings with the green ones due to age. You also need to change the dryer and oil in compressor if you don't change compressor. Check Autozone or O riellys. They can put you on track for cost to change. Also check Rockauto.com for best prices.
Bird - Would you mind to point me in the right direction if you have any websites? Any I've found say to replace pretty much everything, or r12 for outrageous prices.
Thanks! I'll start looking some more then i guess.
If only you were closer to NJ. I'd bring it to you!
โNov-14-2016 03:08 PM
โNov-14-2016 02:46 PM
โNov-14-2016 11:55 AM
โNov-14-2016 11:14 AM
joexsmoot wrote:
I could replace it but i'm trying to avoid that because of the high costs the refrigerant.
โNov-14-2016 10:23 AM
โNov-14-2016 10:20 AM
Bird Freak wrote:
Some one is ripping you off! R134 conversion kits are cheap and there are r12 compatible refrigerants available. Been doing this for years.
โNov-14-2016 10:18 AM
Sam Spade wrote:joexsmoot wrote:
Is it possible and realistic to remove the A/C compressor and install an additional alternator in it's place?
What do you all think?? Let me know, feel free to give me any ideas or issues you forsee in the future!
Possible, probably.
Realistic, certainly NOT.
โNov-14-2016 10:04 AM
โNov-14-2016 07:52 AM
