E-450 alignment!!!
Toot_Mc
I know the topic has been beat to death...!!! Several weeks ago someone posted a place in Houston that aligns rev's and did a good job on there E-450. I took the name of alignment folks down but I have lost same. I want to order 3er party bushings and try to get my coach to stop wondering around in the wind so much.
Any help will be greatly appreciated.
Driving from Houston to Amerillo a couple of weeks ago with wind gust to 30 made me believe I needed a little help. front end felt like it was on ice..!! Haha wasn't funny at the time.
Coach House 261 XL Platinum
2009 Lincoln MKX AWD
2005 Honda CRV AWD
Airforce1 towd Brake system
2011 VESPA GTV 300
US Navy 1954->62, EM-1, USS Boxer CVA-21, USS Essex CVA-9
19 REPLIES 19
Solo
Harvard wrote:
You are on the right track, just do not consider the job complete until you get at least +5.0 caster on LH and about +5.5 caster on right hand. Make sure you can see the alignment report. Good luck.
BTW, it is easy to install the sleeves as a DIY project if you are a Red Green type of guy ๐Ÿ™‚ PM me for details.
Before I started in an attempt to get our former 23D Aspect handling a bit better, I only had an approximate +1.5 Caster on each side. I could only get a total of +4.5 out of the sleeves but the result was worth the effort. Certainly not a silver bullet by any means but just another addition to the growing list of adjustments I made on that Class C. I also added just a bit more toe for a total of +3/16" which I felt tightened the steering feel some. Camber was way positive when new from Winnebago too which caused exceesive tire wear. New shocks, tires, air bags in the rear, trac bar, heavier sway bars, steering stabalizers and adjusting tire pressures to meet corner weights all helped make our Aspect handle much better.
I was shooting to improve the handling which I accomplished but didn't want to fool myself that it was going to handle "like an SUV". Safe to drive I felt now in modest winds (and we do have winds here in the midwest!) and worth my effort for sure.
Solo
2011 Itasca Ellipse 42QD, 450 HP ISL Cummins
2012 Jeep JKU with SMI DUO Braking System
Harvard
j-d wrote:
Some shops will say adjustable sleeves aren't for RV's. Actually, catalogs don't list them for RV's and Box Trucks. They don't have the locating/indexing key that fixed ones do, and the worry is they'll work loose. ...
I am of the opinion the main reason for the keyed bushings is to make the alignment job on the assembly line a 2 minute "tweak the toe and its good to go" job. And that is what the RV owner gets, a one size (caster and camber) fits all with the keyed bushing. JMO.
j-d
This from the folks at Henderson's Line Up in Grants Pass OR. If the parts are assembled clean and grease/oil free, and the pinch bolt is properly torqued, those adjustable bushings WILL stay in place. The torque spec for that bolt is pretty high for the size of the bolt, 65-70 ft-lb if I remember. The instruction sheet tells you.
Henderson repeats the Caster spec Harvard quoted, zero Camber, just a little positive toe, say 1/8" toe-in.
Sam_Spade
The caster modification makes a WORLD of difference......with eliminating most of the "wandering" when there is no apparent reason for it.
BUT....It won't really help much when there IS a reason, like strong cross winds or another large vehicle overtaking you from the rear.
Still well worth the money in my opinion.
Note: The first place I went to insisted that I needed a whole front end rebuild, to the tune of something near $1000 IIRC. The second did it for a little less than $300, without any new parts except the sleeves.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
Harvard
