Electric repair shop
Bill-R
I am looking for a repair shop that specializes in trouble shooting electrical system in a class A diesel motor home. Motor home is a 1989 executive 36xl model with a Cummings diesel engine. Shop has to know solar as the motor home has a solar installed on it. Modesto Ca area. Can be a mobile service or a shop. Thanks for any information provided.
Bill Roop
1989 36'ft DP Executive
5 REPLIES 5
Artum_Snowbird
Pretty simple stuff. Can you use a meter? What is the voltage on the house battery? What is the voltage on the 12 volt circuit panel?
Does it work when you jumper the two batteries? Does it work when you only jumper one side?
Assuming a good battery in the house, jumper from the house battery to the 12 volt panel, first do the negative side. Does it work now? Try the positive side? Try both together?
Something is disconnected or loose. That should find it.
Mike
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
Bill-R
solar is charging starting battery not the house. when you disconnect the starting battery no 12 volt in the motor home.
Bill Roop
wildmanbaker
You may want to contact an Electricians Union and try to get them to recommend a contractor who is qualified in the discipline's you require.
Wildmanbaker
wildmanbaker
Wildmanbaker
Mandalay_Parr
What is the issue?
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
