Electric steps
myface
Does any one know where I can find wiring diagram for electric steps. Previous owner did some "modifications" and cut some wires off.
2001 Brave SE 29A
11 REPLIES 11
RLS7201
Control unit $117.16
Door magnet for new style control box $22.63
I have done this upgrade to older Kwikee steps and it works.
You may need to change the wiring connector for the motor.
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
enblethen
You can get a complete step assembly at Colaw for less then that!
Control unit is also available there. I have one in my garage! What is the numbers on your controller? PM me!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
myface
OUCH. I just put a rocker switch by the door.
dougrainer
Since you have a 2001. The step controller is no longer available. This link points you to the ONLY and best solution for getting your step back to OEM. Doug
https://store.lci1.com/kwikee-step-motor-conversion-kit-for-triple-and-quad-steps-kwik-step-motor-ki...
enblethen
I would not condem the controller without doing some testing. Quite often there could be ground issue or the magnetic door switch.
Control box should be available from Colaw RV salvage. Colaw
What color is the controller?
Bud
USAF Retired
Pace Arrow
myface
The previous owner cut the wire from control box and run wire straight from motor to battery with alligator clips. It could be that control box give up and he bypass. I got some work to do with that.
myface
Thank you for the wiring diagram. I will check it out.
enblethen
The 16 gauge purple wire is not normally used. It is used on some for optional(extra)step lights.
Bud
USAF Retired
Pace Arrow
wa8yxm
Just so you know.. On my Steps there is a wire that is cut... Still not sure what it is for. the reason it's cut is it has no use... It appears to be an "Extra wire" near as I can tell.
Lwiddis
Bless those former owners who cut wires off, for they know not what they do.
enblethen
I am guessing you have a Kwikee step.
Kwikee wiring diagram
Bud
USAF Retired
Pace Arrow
