Jul-15-2017 12:52 PM
Jul-16-2017 11:14 AM
Bud
USAF Retired
Pace Arrow
mike brez wrote:. I found the one wire from the fuel pump relay and followed it down and it went to some kind of switch , it was difficult to see I could only feel it. It was on the frame not on the block.enblethen wrote:
The fuel pump sending unit has three wires not one.
oil pressure sending unit
As for testing, it is hard to verify that the contacts are not pitted to the point of increasing resistance that causes the voltage drop.
I noticed that my oil pressure gauge had changed slightly indicating higher oil pressure. I changed the sending unit and the gauge started registering closer to where it was.
The fuel pump relay only operates to pressurize the system. It does not operate under normal pump operation. It runs for 2 to 10 seconds when ignition is first turned to "on".
If that was directed to me I was talking oil pressure switch
Jul-16-2017 11:08 AM
enblethen wrote:. I can't view either link you sent.
No, I messed up. Left side
Fuel pump relay
Jul-16-2017 11:07 AM
Jul-16-2017 11:05 AM
Jul-16-2017 11:00 AM
Jul-16-2017 10:59 AM
enblethen wrote:Are you saying it is on the passenger side? I found a relay on the drivers side that is black oval shaped about 2 ins long with 5 spade connections 3 large and 2 small.
I cannot here my pump without putting screw driver against tank and ear.
FYI the fuel pump relay is on the right side of engine compartment on a sheet metal panel along a tubular brace.
Jul-16-2017 10:50 AM
Bud
USAF Retired
Pace Arrow
Jul-16-2017 10:49 AM
Bud
USAF Retired
Pace Arrow
Jul-16-2017 10:47 AM
enblethen wrote:. Thanks Bud, I also put my fingers on the relay and can't feel any clicking, are you saying that the oil pressure sending unit controls this relay? I could not open the link you sent me, but what I think is the sending unit is about 1 in in Dia and 3 ins long and has about 5 wires attached to it.
Jul-16-2017 10:31 AM
Jul-16-2017 10:23 AM
Bud
USAF Retired
Pace Arrow
Jul-16-2017 10:09 AM
Jul-16-2017 09:49 AM
Jul-16-2017 09:46 AM
