Engine will not crank over
Randy69
I have a 1998 Four winns windsport class A motorhome. 7.4liter GMC engine. Engine will not crank over, no power to solenoid on starter. Will start if I cross starter solenoid with screwdriver and key on.
No power to crank fuse, even when key is in crank position. Ignition switch has power to it and send power out in crank position. Does anyone know if they have a fusible link some where?
9 REPLIES 9
JimM68
For sure an interlock of some sort.
Could even be jacks down or slides out.
Jim M.
2008 Monaco Knight 40skq, moho #2
The "68"
My very own new forumfirstgens.com
My new blog
fourmat
my bet is neutral switch try moving the shifter while holding key to start or jump the switch and see if it starts
2009 Challenger
Paul_G_
I had this same problem years ago. After much reading, I found the problem. Ground the starter to the frame, use jumper cables to test if it works. I then bought a battery cable with two female ends and bolted one to the frame and the other to a starter bolt. I did this in February in Minnesota as it happened a couple of days before winter vacation.
Good luck.
Paul...
enblethen
Does the lights on the dash come on? If they do not, check the main fuse link adjacent to large terminal on the starter. The fuse link attaches to the main post and feeds the fuse block under the dash.
There should also be a main fuse labeled "IGN"
If lights come on check the connector on the ignition switch. It is located on the steering column adjacent to brake pedal. Make sure switch is tightly mounted.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Daveinet
Yes, I tried to post that an hour ago, but RVnet refused to post. Switch is on the column, but there may be a switch on the side of the trans as well.
My coach is ornery at this, so once in a while, I hold my key to start and move the lever around till it cranks.
IRV2
SAR_Tracker
K Charles wrote:
check the neutral start switch, or park, whatever.
What ^^^^^ said.
Rusty & Cheryl
2011 F250 2WD 6.2L Gasser
2008 Weekend Warrior FB2100
"Common sense is in spite of, not the result of, education" - Victor Hugo (1802-1885)
K_Charles
pianotuna
Nomad III
Nomad III
Hi,
My 1987 Ford e-350 diesel had dual solenoids. Trace the wire back from the starter and hope to find the source of the problem?
Regards, Don
1492
Moderator
Moderator
Moved from Forum Technical Support
