Jun-12-2020 07:50 AM
Jul-08-2020 06:03 PM
MRUSA wrote:dougrainer wrote:
PS, This was years before Thor thought about buying Jayco.
One of the things that I thought was crazy---they installed the slide out controls and switches IN THE CENTER BATH. HOW COULD YOU OBSERVE THE OPERATION OF THE SLIDE ROOMS WHEN ACTIVATING?
BECAUSE ENTEGRA DP COACHES ALL COME WITH A HAND HELD REMOTE THAT CAN ACTIVATE THE SLIDE OUTS FROM ANYWHERE IN THE COACH OR EVEN FROM OUTSIDE THE COACH.
Jul-08-2020 05:12 PM
Jul-07-2020 10:27 AM
Jul-07-2020 09:23 AM
Jul-07-2020 07:43 AM
way2roll wrote:dougrainer wrote:Ro"n"Joe wrote:
The original Entegra DPs (Aspires, Anthems, Cornerstones) are quality products. Since Thor purchase, not sure about the "newer" lower end units. Are they dressed up Thor units with the Entegra sticker?
I don't understand the logic of people that think this. Thor Purchased Jayco. That's all Thor does. They are a Holding company. They find what they consider Good RV related companies and buy them. They do NOT change the production or sub Culture of the companies they buy. The reason they bought them is because of the management. They are NOT interested in turning around poor run companies. Doug (works for a Jayco and Airstream dealer(Thor owned also) as a Service tech)
While I agree with most of your posts, I have to disagree on this one. Since Thor's purchase of Entegra they are producing an entry level gasser that is a far cry from the higher end products Entegra is known for.
Jul-07-2020 07:13 AM
Jul-07-2020 05:57 AM
Jul-06-2020 06:46 PM
Jul-02-2020 09:14 AM
wowens79 wrote:
Check with your state, you may have a 7 day backout period where you can return the unit. If they think they will have to undo the sale, I bet it will get the problem solved quickly.
Jul-02-2020 08:24 AM
Jul-02-2020 08:02 AM
Jun-12-2020 06:43 PM
dougrainer wrote:
With Covid 19, Jayco is way behind in authorizing warranty work. Floor repair REQUIRES Pre Authorization from Jayco if it goes over 6 hours. SMART dealerships get the unit in just for checkout and pics and then let the customer go and use the RV. The dealership warranty dept then sends the pics and estimate of what they want to do with Labor and Parts. It can take up to 2 weeks in normal times, but who cares as long as you are using the unit. Once Auth, the dealer calls the customer and schedules the unit back in. Now, for bubbles, the usual way to repair is either cut along the edge of the closest Cabinet and lift and glue or use the syringe to inject glue into the bubble spots, then install a flat plate with a heavy item(I use bad 12 volt batteries) overnight to set the glue. Rarely does the entire floor have to be replaced for bubble type problems and even then, 20 to 25 hours is the labor time. We use a Flooring company to replace Lino type floors when doing a complete RV as they can fit and cut perfectly as they do this type work all the time.
Jun-12-2020 04:36 PM
Jun-12-2020 03:00 PM
