Exterior outlet on Winnebago
jspringator
I have the beginning of delam under the exterior outlet on my Winnebago. The outlet appears to be of an unusual design that I can't find anywhere. Does anyone have a link to a new one?
I tightened it up, but I would feel better replacing the whole thing.
Untitled by jspringator, on Flickr
Jim & Sherri
02 Winnebago Sightseer 27c Class A;
"Scout" Springer Spaniel, gone but not forgotten;
"Boo" Chocolate Labradoodle.
8 REPLIES 8
jspringator
The stainless steel clothes pins work.
Here is an Amazon link.
https://www.amazon.com/gp/product/B01NBR79Z1/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1
Jim & Sherri
jspringator
UPDATE. The weather cover I ordered did not fit. I taped the cover, off, painted it, and ran a good sized bead of caulk around the top and sides. I used 3M4000 UV. Later, I plan to mount one of those flaxible plastic gutters over this outlet, and eash window.
I'm also trying some stainless steel clothes pins to attach to the end of each gutter. I'll do another post after I see if they work.
Jim & Sherri
D_E_Bishop
My Winnie is in storage right now so I cannot look at my outlet for name and number but look in Winnebagoind.com for the resources tab and download the parts list for your rig.
We seldom use our exterior outlet and have not had any problems with water. Just follow Winnie's procedures and you should be fine.
David Bishop
2002 Winnebago Adventurer 32V
2009 GMC Canyon
Roadmaster 5000
BrakeBuddy Classic II
wa8yxm
Better caulking around the box..
That is not why I'm opposed to 'em.. I'm opposed cause they have a nasty tendency to melt down if you draw more than about 10 amps.
jspringator
Got any suggestions for a more water-tight replacement?
Jim & Sherri
wa8yxm
That is a "Unibox" or Quick box outlet. Very common in RV's. and becomming more common in houses. and in my personal opinion JUNK. but that is a more detailed post than I wish to make now.
jspringator
Thanks! I just ordered the weather cover.
https://www.amazon.com/Diamond-Group-52516-Weatherproof-Receptacle/dp/B007HRQ1RA/ref=pd_bxgy_263_img...
Jim & Sherri
Ranger_Smith
https://www.amazon.com/Diamond-Group-WDR15WT-White-Receptacle/dp/B004M8N5A8/ref=sr_1_7?ie=UTF8&qid=1539695040&sr=8-7&keywords=rv+electrical+outlet&dpID=31Ea7me9FgL&preST=_SY300_QL70_&dpSrc=srch
Where we are now
Amateur Radio Operator WW1SS . . . Flex 6500 PGXL and TGXL
Steve and Joy
2014 Itasca Suncruiser 38Q . . . 2016 Lincoln MKX
The Doodles, Abbie & Abel
Baby and Kissie the Chihuahuas and Lucy the Biewere Yorkie
