Oct-27-2014 04:55 PM
Nov-13-2014 09:57 AM
Nov-06-2014 04:57 PM
John&Joey wrote:
As far as the spongy brake pedal, you may want to drive the rig for awhile then do the bleed. As I remember the caliper is setup to capture the air and will bleed when cracked. Sometimes you just have to let things come into balance (as long as it's safe) before you go forward.
Nov-06-2014 04:55 PM
RLS7201 wrote:
Mr. treeDodgingCamper,
While looking at your last pictures I saw your sway bar end link and that reminded me of the high failure rate of the sway bar bushings on the rear axle. Take a look-see while your there. There is a guy on Ebay (skuterdude) that has urethane replacement bushings for a good price. He has been selling bushings for 5 or 6 years. I have some of his first offerings and they still look good.
Richard
95 Bounder F53
Nov-05-2014 05:23 PM
Richard
95 Bounder F53
Nov-05-2014 04:32 PM
Nov-05-2014 03:45 PM
John&Joey wrote:
Very good chance the prior owner cooked that rotor. You either have hard and soft spots on it, or it is warped causing the pulsing pedal. Also notice the uneven wear on the pad, meaning less contact area for braking power.
Nov-05-2014 04:35 AM
Nov-05-2014 04:24 AM
Nov-05-2014 04:11 AM
Nov-04-2014 11:50 AM
ddndoug wrote:
Glad that it sounds like you have it figured out.
Doug
Nov-04-2014 11:13 AM
Nov-03-2014 09:13 PM
Nov-03-2014 08:36 AM
Big Katuna wrote:treeDodgingCamper wrote:
Oh, and if anyone is curious, these Napa brake hoses were made in China. Brand name is Sunsong. I'll be replacing them asap, I don't trust anything made in China.
Why I recommended OEM. Usually Hecho in Mexico with American supervised inspection.
Nov-03-2014 07:43 AM
