Mar-04-2020 07:22 AM
Mar-04-2020 11:52 AM
Chum lee wrote:
Only use the specified brake fluid if you need to top off. (see your owners manual or the reservoir on the MC)
Chum lee
Mar-04-2020 11:05 AM
MetalGator wrote:
The motorhome is still under warranty (Ford) until June so I took it to a large Ford truck dealership that's nearby. I called today to get a status and the service rep said they were waiting on a part, some type of cylinder. I am assuming he was referring to the brake master cylinder.
I only have a little over 11K miles on the motorhome. Is this type of failure common on the F53 chases? I haven't seen much mention of master cylinder failures on the F53 so I am hoping this is an isolated incident.
Burch
Mar-04-2020 10:49 AM
Mar-04-2020 10:14 AM
RLS7201 wrote:
Right and left side of vehicles are referenced like you are sitting in the driver's seat.
That puts the master cylinder on the front left side.
Richard
Mar-04-2020 09:49 AM
MetalGator wrote:
The brake cylinder is on the front right. It's way up in the engine compartment. I don't see how you could even add fluid to it as there is really no room above it. Underneath the master cylinder looks like the power steering. Under that is the windshield washer fluid tank. The washer fluid tank had a film of oily/water solution on it after my last trip. The fluid got on part of the frame of the motorhome and the black paint is starting to bubble. I have been told that brake fluid will do this to paint.
Mar-04-2020 09:24 AM
Mar-04-2020 08:11 AM
