F53 Rear sway bar bushings
22WANDER
I have a 2006 Ford f53 chassis and the rear sway bar bushings are gone. How hard are they to replace? Is it something I can I do myself?
The Ford guys want $250. to replace them. Seems high. Online I can buy them for $30 dollars. Any help would appreciated.
18 REPLIES 18
22WANDER
When you say jack up do you mean with the Rv leveler jacks or a bottle type jack?
rgatijnet1
Once you jack up the rear end to relieve the pressure on the anti-sway bar, changing the bushings is not that difficult. The bolts/nuts may be rusted and will need some penetrating oil to break them loose.
22WANDER
Thanks for the info.I will do that.
rgatijnet1
If you buy them, get the urethane bushings instead of the original rubber bushings. That will be the last time you replace them.
