โMar-27-2014 10:02 AM
โMar-27-2014 08:35 PM
โMar-27-2014 07:10 PM
โMar-27-2014 06:43 PM
KD4UPL wrote:This is basically what I do. My transmission shifts into 4 gear at 45 mpg on a flat road, if I travel at 50 mpg it will not downshift on slight hills. Also by not using cruise control and accelerating slightly I can keep it in 4th gear without downshifting when approaching a hill. I also still use a vacuum gauge to drive(I'm old) and know when it will down shift based on vacuum readings so I take my foot off the pedal and reduce speed before it downshifts keeping it in 4th gear. If you have a 5 or 6 speed your speed will be higher.
Around here the minimum speed on interstates is 45 but the limit is 70. Are you saying everybody is happy if you poke along at 50 in a 70? I'm pretty sure they're not.
OP, slower is the answer to a point. You need to be at the engine's peak torque RPM while your transmission is in it's top gear. That should theoretically be your best MPG.
โMar-27-2014 05:44 PM
โMar-27-2014 03:51 PM
โMar-27-2014 11:33 AM
โMar-27-2014 10:28 AM
โMar-27-2014 10:15 AM
โMar-27-2014 10:13 AM
โMar-27-2014 10:08 AM
