Firestone Airbags on an F53, where's your PSI?
Mike_M2
On my 1999 F53 chassis i have been playing with the pressure in the bags and have found that i like the ride around 25 PSI or so all the way around. I was wondering how much air everybody else uses? Also, how often do you have to add air?
Mike M2
Thor Infinity 33SL
7 REPLIES 7
camperkids1025
MikeM2 Like Fred said it all depends on what works for you. I just installed a set of Air Lift on the back of my F53. I took a trip to the Finger Lakes NY and had mine set at 50 psi and loved the way it sat and handled. I also installed a on-board remotely controlled air compressor set it at 50 psi and it's automatic and I'm good to go and change it on the move. Best thing since sliced bread. It is normal for them to lose some air and have to readjust the pressure. Jim
The Camperkids Jim & Lois
3 Grandkids Maria, Christian, Antony (part timers)
1999 Newmar Mountain Aire 37.5ft, Ford V-10, F-53 Chassis, Bilsteins Shocks W/ Bilstein Steering Stablizer, HWH Levelers
Mike_M2
How often does everybody have to add air? My front bags are brand new and it seems like every few weeks it loses 5 or 10 PSI...
Mike M2
Thor Infinity 33SL
koda55
I found for us it rides the smoothest in the rear with 65lbs per side. In the front I run 25lbs.
pkunk
I run 25-30 if my water tank is almost empty and bump up to 60 with a full tank.
I only have rear bags
1999 Coachman Mirada 34 ft.V10-F53 chassis
12ft.LR slide-2 gp31 AGM 12V @220AH
topflite51
I have a '97 chassis, I installed the air bags. Testing various pressures I found 75 in rear and 25 in front work best for my rig.
:CDavid
Just rolling along enjoying life
w/F53 Southwind towing a 87 Samurai or 01 Grand Vitara looking to fish
Simply Despicable ๐Ÿ˜›
Any errors are a result of CRS.:s
427435
Mine was low and leaning to the passenger side (kitchen side). I run 100 psi on that side and 50 psi on the driver side. It's now level front to back and side to side.
Mark
2000 Itasca Suncruiser 35U on a Ford chassis, 80,000 miles
2003 Ford Explorer toad with Ready Brake supplemental brakes,
Ready Brute tow bar, and Demco base plate.
Golden_HVAC
I have a 97, and it did not come with air bags. I don't think they where factory installed. You can use whatever pressure you happen to like.
I would not put in a bunch of pressure, like you found, 25 PSI takes some of the weight off the springs, and does not give a harsh ride.
Fred.
Money can't buy happiness but somehow it's more comfortable to cry in a
Porsche or Country Coach!
I havn't been everywhere, but it's on my list.
Kangen.com Alkaline water
Escapees.com
