Fog light switch?
homedad
I have a 2 week old 2014 Fleetwood Storm 32H and am learning how everything works. I've figured out just about everything by trial and error and assistance here since most of the manuals don't help. I have this switch to the left of the steering wheel that doesn't seem to work. I was told that is is for the fog lights. I see the lights under the headlights and next to the turn signals but can't get them to turn on. I tried the switch by itself, with headlights, with parking lights, with engine running, engine off, in drive, in park, inst. dimmer on, off and in between. I looked at the Ford manual and checked the fuses in the left dash. Nothing seems to get the switch to do anything. If the picture works it is the second switch to the right of the leveler control panel. Thanks
http://i1283.photobucket.com/albums/a556/homedad2/2014stormleftdriver_zps00d3a646.jpg
3 REPLIES 3
campinginthewoo
On my Ford my fog lights operate by pulling the headlight switch out. and pushing it in turns them off. I do have automatic headlights so my switch also moves one spot left but your picture doesn't look like you have that option. Good Luck
"Our family is a circle of love and strength.
With every birth and every union, the circle grows. Every joy shared adds more love.
Every crisis faced together makes the circle stronger. "
homedad
Thanks. I just went out and tried the high-lo beams. They come on with the switch when high beams only are on. At least I know that the switch does something.
Jayco23FB
If they are fog lights try them with the headlights on "low beam" most fog lights work only in low beam. If they are driving lights they will work with high beam.
Jayco G2 23FB
2007 Chevrolet 2500HD 6.0L
