โOct-27-2018 02:30 PM
โOct-29-2018 11:10 AM
fairway2002 wrote:carringb wrote:
Yup. Diameters don't match. Either replace the other side, or switch to a 2-channel valve setup, so each side will be leveled independent. Independent control will reduce body roll as well, since air won't transfer when weight transfers in turns.
This is interesting. Explain a little more. If I have 100lbs (this is just a value for conversation) in each bag with a single valve. How does a 100lbs in each bag with two valves help role? I trouble shoot electronics so I see things different
Thanks
โOct-29-2018 10:16 AM
โOct-28-2018 06:26 PM
โOct-28-2018 10:55 AM
โOct-28-2018 10:08 AM
โOct-28-2018 09:09 AM
Big Katuna wrote:Ivylog wrote:fairway2002 wrote:
So, how is left/right ride height in back?
Back is perfect.
Now youโve gotten my attention. The area of the new bag is smaller than the original...they did not replace with the correct air bag.
Thatโs what I was guessing too. Rear valves put the correct amount of air in, bag is taller.
Replacing other bag will probably result in the front being too high or rear being too low.
โOct-28-2018 08:56 AM
Back is perfect.
โOct-28-2018 08:21 AM
Back is perfect.
โOct-28-2018 07:19 AM
wolfe10 wrote:Ivylog wrote:
Side to side is controlled by the 2 rear ride height valves. Adjust the rear one on that side.
Correct. So, how is left/right ride height in back?
โOct-28-2018 06:33 AM
โOct-28-2018 06:29 AM
MrWizard wrote:
i'm only guessing
but the New one maybe stiffer, the old may stretch more when inflated with the same pressure
i think i would replace the other old one with a new one, keep it for an emg spare
โOct-28-2018 04:33 AM
โOct-27-2018 08:41 PM
โOct-27-2018 07:23 PM
