front vs rear diesel
Vacationer04
Looking at a FRED diesel Tiffin coach. What are the big negatives if any of the front vs rear versions? It is a Cummins while most of the rears are Freightliner. Does that also make a big difference? Have never owned one in the past as I wanted to do my own maintenance which is why I bought gas chassis instead.
THANKS!
Jim & Linda E.
'04 Holiday Rambler Vacationer 36WDD, 2 slides
'03 Honda CR-V EX Awd
Demco Kar-Bar & baseplate
Brake Buddy Classic
"Don't tell me it can't be done, just tell me it won't be easy."
"If I can't buy what I need, I'll make it myself."
19 REPLIES 19
Johnny_G1
I don't find a problem with noise and I do have air suspension all around.
98 Mountain Aire 34' 210 Cummins Puller and 2001 dodge dully with all the toy's, 400 + hp pullin a 2001 32.5' Okanogan 5th wheel, new to us after 5 yrs with the 28' Travel Aire. Lots of fun.
Fishinghat
Two Hands wrote:
Diesel engine in the front - loud. Diesel in the rear - much quieter. I have had a gas motorhome and now a diesel pusher. I could never go back to a gasser.
X2
Drive both to truly understand the difference.
Holiday Rambler Navigator DP, Hummer, and Honda VT1100C Shadow
Dale_Traveling
If I'm not mistaken Tiffin used Freightliner chassis with the Cummins engine. You won't have the air bag suspension and other ride improvements a full up DP has but I would expect your fuel usage should be a bit better than a gas powered coach. For a bit more chassis info click HERE.
Also don't confuse Freightliner with Cummins. Freightliner makes the chassis or frame then bolts a Cummins engine in place. Same as Workhouse. Workhouse built the frame and installed a GM power train. Two separate companies.
2006 Hurricane 31D built on a 2006 Ford F53
Two_Hands
2015 Fleetwood Excursion 33D
2016 Grand Cherokee Limited
Retired Law Enforcement
U.S. Army 1965-1973/RVN 1968-'69
I am the frequent recipient of "Get out of the way old man!"
wolfe10
Freightliner makes both chassis, though Tiffin did use other chassis.
Both also with Cummins engine.
Go here for the specs: http://freightlinerchassis.com/component/option,com_servicecenters/controller,oem/oem,Tiffin/view,oe...
Just click on the year and model you are interested in.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
