Furnace black smoke
Holiday27
Hi All,
Hoping I can get some furnace help. With searching I had no luck.... When I run my furnace I get stinky dark smoke. Here's the weird part. I pulled it out and bought the proper connectors and hooked it up to my car and a propane tank and it ran fine. My fridge and stove work well. Do I have an issue with my propane regulator on my RV though? I don't understand why the furnace runs dirty in the RV.
Anyone have any ideas? Thank you!!
2002 27PBS Holiday Rambler (Aluminum sided/roof) Love it!
Previous RV's
'94 Jamboree 22ft. (This beast had a 460 with tons of power)
'95 VW Eurovan camper (5 cyl. dog) Pulled a 3 rail fine though.
Tent:(
Borrowed folks '84 VW Westfalia (water cooled)
26 REPLIES 26
bobndot
Holiday27 wrote:
wolfe10 wrote:
OR a rusted/damaged burner or perhaps a mud dubber has set up housekeeping.
Either will disrupt the fuel/air mixture, same as improper propane pressure.
Yeah, I went through all that, even replacing the burner components. It's got to be the propane regulator....
Thanks for the feedback!
Quick test:
If you light your stove , observe the flame as you turn on the water heater. If the stoveโ€™s flame diminishes as the WH fires up, i would suspect the LP regulator.
Holiday27
bgum wrote:
Please let us know the outcome. I am convinced it is air in-out-or both.
Will do, funny how the fridge and cook top work fine though. Im guessing im not getting enough gas pressure to the furnace but who knows.... Thanks for the info!
Previous RV's
Tent:(
Holiday27
Previous RV's
Tent:(
wolfe10
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
bgum
Pbutler97
Holiday27 wrote:
Pbutler97 wrote:
I would check the regulator output for 11" WC.
Can I check on my own or do I need to take it to a shop?
Thanks!
Check it yourself.
Click
Click
Holiday27
Thanks!
Previous RV's
Tent:(
Holiday27
midnightsadie wrote:
could be a blocked fresh air intake. clean the intake and exhaust pipes. just a though.
I've cleaned everything, intake and exhaust so I think I have that area covered. Thanks for the ideas though.
Previous RV's
Tent:(
Holiday27
bgum wrote:
Would this be caused by air fuel mixture?
Maybe, but it runs fine outside the RV.
Previous RV's
Tent:(
Pbutler97
midnightsadie
bgum
