Generator ? Generec Q-55G
Getsome2
I have a 33' Rexair.
The Generator is a Generec Q-55G with 1500 hours.
The motor runs strong but the Generator seems loud. Almost like metal is hitting a pulley or something.
It does not change much if you have the charging set on Off, 20 or 50 Amps.
Do any of you Folks have any similar experiences with a Generator that might give me a direction to start trouble shooting this issue?
Thanks for any impute.
4 REPLIES 4
Getsome2
Maybe I will barrow a trans jack from my pal and pull it out. If I get it out of the cubby hole it is stuck into I bet I could get a look at it.
Thank You Dennis.
Executive45
Time to get a stethoscope from Harbor Freight and do some sleuthing... Might just be the shroud came loose somewhere and is now rubbing. Sound, like water, can travel well beyond where it's actually coming from. Usually, if it's a bearing you'll get an overheating problem with it as friction produces heat....get the stethoscope and hopefully track down the problem. You might look for new worn spots around the unit in the meantime and get lucky....Dennis
We can do more than we think we can, but most do less than we think we do
Dennis and Debi Fourteen Years Full Timing
Monaco Executive M-45PBQ Quad Slide
525HP Cummins ISM 6 Spd Allison
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
Getsome2
Hi Dennis and thanks for responding.
We bought this Coach about two years ago. We use it to travel to Motocross Races.
I do not remember it being this loud in the past but we can go Months between using it. I do run both the Motor Home and Generator every 3 or 4 weeks driving it a couple of miles each time. As I posted the Generec motor sounds fine and runs strong. It sounds like something rubbing? It is not a knocking sound but a consistent sound almost as if something was rubbing a shroud? Maybe a bearing?
Executive45
Is this a "new" issue or ?..has it run quietly in the past?..Dennis
