Generator radiator removal
mike_brez
I have a Power Tech 8kw Model IDL 8000 with a Isuzu 3LB1PV02 engine on a front slide out. Just looked real quick but looks pretty tight to remove in place.
Not looking forward to do this.
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
10 REPLIES 10
mike_brez
Just a up date. Have put over 100 hours on generator after repair and all is still good.
2015 Wrangler JKU
mike_brez
Put radiator in tote with water and pumped up to 20lbs, let sit for 15min I figured to let everything equalize and lowered to 19lbs.
Held at 19lbs for over two hours. Radiator cap says 17lbs on it so I’m calling it good for now. Repainted the shroud and took belt off. Going to grab a belt while it’s all apart.
2015 Wrangler JKU
mike_brez
Had some time today so i air tested and found a few leaks.
Soldered them up the best I could(they ain’t pretty)holding air fairly well but still dropping some psi on the gauge and can’t see anything else using soapy water in a spray bottle.
Going to grab one of my tucker totes tomorrow and fill with water and submerge it and air text.
Also started to drill out one of the broken bolts so I can tap and battery drill died.
2015 Wrangler JKU
sprintmod1
If its not repairable and you can't find a suitable used one, you may want to look around at the racing industry. There are companies out there that make radiators for race cars that are "custom" and may be very reasonable.
You also might be able to look at someplace like "Jegs" and see what they might have listed and available and sizes. Might take some creativity to get hose connections in the right place or right size, but its very possible.
Good Luck!
2010 American Coach Revolution 42w; carrying 2014 HD Electra Glide Limited and towing 2015 Chevy Silverado 2500HD.
Dirt's for racing and asphalt for getting there.
410 Sprint Car's rule!
mike_brez
Well it’s possible with a couple broken bolts a couple scrapes and a handful of bad words.
Now to try and repair or find a new one. This is probably going to be the worse part.
2015 Wrangler JKU
mike_brez
Got email just as I figured,no radiator or even a part number available. Was told they were specially made and sent to power tech for install.
Jeff coming back middle of next week trish couldn’t say if it was possible to remove while in coach. I’m thinking I’m just going to pull it out
2015 Wrangler JKU
mike_brez
Waiting for a email
2015 Wrangler JKU
wolfe10
What was her recommendation?
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
mike_brez
wolfe10 wrote:
Don't know with the COVID 19 about their hours/who is on-duty, but:
Call Power Tech at 800 760 0027. Go to tech extension 3. Speak with Jeff.
Plan B, speak with another Power Tech tech.
Yep emailed them already. I emailed Jeff directly to his email last week and got a reply back from Trish?
2015 Wrangler JKU
wolfe10
Brett Wolfe
Ex: 1997 Safari 35'
