GFI Popped and Won't Reset
Merry
The gfi outlet in the kitchen area of our Pleasure Way popped and we can't get it to reset. We don't know why it blew. This controls all outlets plus the refrigerator etc. Frig and hot water are running on propane. We have checked all obvious causes such as fuses. I'm sure we are just missing something simple. This is a brand new unit. This is the first time we stayed in it since we bought it a month ago. Right after we signed all the papers, I received a phone call that my elderly mother and fallen and needed surgery immediately so we have been staying with her or I'm sure this would problem would have come up sooner? We bought at Lazy Days and I will call them if we can't get it working.
Thanks so much for any suggestions.
2014 Pleasure-Way Pursuit (B+)
15 REPLIES 15
enblethen
A GFCI receptacle will not reset if there is no power to it.
Verify that a 120 volt circuit breaker has not tripped. If you are not sure which one,Shut off all circuit breakers, apply slight pressure toward "off". Then turn main breaker if equipped on, then each branch breaker one at a time.
Next it could be a problem in the circuit. Remove GFCI receptacle from the wall. Locate and disconnect "load" side wires, disconnect the black and try resetting. No reset, verify power to the GFCI receptacle. If power is present, replace GFCI receptacle.
The GFCI receptacles are the same as residential/ commercial ones.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
