Jul-20-2015 08:19 AM
Jul-22-2015 09:22 AM
2021 Nexus Viper 27V. Class B+
2019 Ford Ranger 4x4
Jul-21-2015 04:03 PM
Jul-21-2015 02:36 PM
Jul-21-2015 01:16 PM
SCVJeff wrote:jorbill2or wrote:If it didnt work they wouldn't build them. Mine is 50' and the pictures are rock solid.
Keep in mind as I was told HDMI cable will not work past 30 feet or so . I haven't tried but was assured that and told to use cat 6 cable for longer runs
Jul-21-2015 01:00 PM
Jul-21-2015 09:58 AM
Jul-21-2015 07:29 AM
Jul-20-2015 09:03 PM
TNGW1500SE wrote:msmith1199 wrote:
I ran an HDMI cable through my duct work and it works just fine. I have a duct running the length of the coach on both sides however. I would assume you could cross over at the A/C unit if you need to.
Just got to take a look at it again. I took off the A/C return duct and I can just run the cables from one side to the other side of the duct work. I will have to bring the cable out of the ceiling back by the bathroom but I think I can just cover it with wood trim. I have some matching panels.
Jul-20-2015 09:00 PM
GordonThree wrote:
Consider this option:
HDMI to Cat6 converter
Adapter box that converts hdmi to inexpensive network cable, and then back again. Uses two pieces of cable, which you can get at best buy super cheap. At nearly 200 ft it should cover anything in an RV 🙂
Jul-20-2015 08:57 PM
GordonThree wrote:
I just re-read OP, source is a laptop - check to see if it already has "Intel Wireless Display" aka "WiDi" aka "Miracast" built in. That's 1/2 of your wireless hdmi solution, the other half being a WiDi receiver.
WiDi will not interfere with your other outputs, it can clone the main display or create its own display... pretty cool stuff actually.
Jul-20-2015 08:56 PM
SCVJeff wrote:
I ran mine from the TV cabinet down in the wall, dropped into the storage bay to the front of the coach, out for several feet around the front generator and suspension, back in and up a side pillar. Sounds easy doesn't it?
Jul-20-2015 08:53 PM
outofplace wrote:
http://www.iogear.com/product/GW3DHDKIT/
Jul-20-2015 08:52 PM
Jul-20-2015 08:44 PM
