Dec-24-2016 02:05 PM
Dec-25-2016 05:15 PM
YC 1 wrote:dougrainer wrote:YC 1 wrote:
I am betting low voltage at the fan is causing the vane switch to not allow the ignition sequence to start.
Time to check the voltage with the fan running right at the heater wires.
Of course a quick battery check would be in order to start.
The OP is NOT having a Lighting problem. They are having a fan NOT shutting OFF after a Heating cycle is complete. Doug
". I can hear the furnace burner shutting down and fan stays on."
If the voltage recovers enough for it to light and come up to temp the voltage could be pulled down enough for the fan to slow and not allow the furnace to light again. I have seen this happen and you end up with a dead battery and cold rv.
Low voltage is easy enough to check for.
Dec-25-2016 04:24 PM
Dec-25-2016 05:49 AM
Dec-25-2016 05:44 AM
filrupmark wrote:
Out of propane ? Never reaching set temperature and fan keeps running.
Dec-25-2016 05:43 AM
Dec-25-2016 05:42 AM
doxiemom11 wrote:
Our fan shuts off just a couple minutes after burner shuts down after the set temp has been reached. It has never even run as long as 5 minutes.
Dec-24-2016 11:11 PM
Dec-24-2016 06:22 PM
Dec-24-2016 05:08 PM
Dec-24-2016 04:52 PM
dianna119 wrote:
Thanks Doug, makes sense. I can hear the furnace burner shutting down and fan stays on. I have left it on for upwards of an hour thinking it should shut off and just blows cold air making the inside cold again and then burner comes on. In previous years, the fan would shut down after about 2-3 minutes. DiAnna
just saw your ps, Yes, the thermostat was replaced same brand/type as original,
Dec-24-2016 02:26 PM
Dec-24-2016 02:21 PM
Dec-24-2016 02:18 PM
