Help 2014 Fleetwood, where is tow brake adapter
dom101
My tow lights went out in Barstow and i can't find the three light signal system to two light system adapter. ie red brake, orange signal, to red brake and signal. It was working until we got to Barstow then quit. I have no power coming out of seven pin plug. I checked at the fuses I could find and suspect its in that adapter, but I don't know where it is. Hoping someone can help
10 REPLIES 10
dougrainer
You will have to call Fleetwood. Adapters are done at the REAR where the Ford chassis harness is located. You need to follow the Tow plug harness and see where it is interconnected. Doug
dom101
Ok rechecked fuses under engine compartment and all are good. Even checked two diodes all are good
dom101
Ok thanks. you are right, tail lights work but no signal or brake. I will check the fuses in that box again, but do you know where the adapter would be? I kinda think that's the problem is, but not sure
dougrainer
OK, The adapter only is for the Left and right turn and Brake lights. The running lights should still work. If the running lights do not work, then either the 7 way at the hitch is unplugged from the Ford Harness or you have NOT found the fuse box up front for the Tow plug wiring. Usually on Ford Chassis's the fuse block is accessed from the front outside hood and is mounted on the outside firewall in front of the drivers seat. Doug
dom101
Its a ford chassis 36 ft
dougrainer
It would help to know what chassis you have. Doug
dom101
I checked all the fuses. Even found the one marked tow brake. MH has red brake and orange signal
wildmanbaker
OK, first check all of your fuses for the chassis. Don't just look at them, actually remove and test them with a VOM. Do you have separate brake and turn lights, or does your MH use the same light for both the brake and turn lights? If it uses the same light, you do not need an converter. The fuse panel you are looking for is probably on the dash in the drivers side.
Oh, and welcome to the forum.
Wildmanbaker
dom101
No. There is no power to brake lights or turn signal. There is no module at the back. I traced wire bundle about halfway up but then they disappear, my last mh the module was nice and handy at the back
wildmanbaker
Are the lights on the MH working in the back? The converter is usually near the receiver hitch underneath.
Wildmanbaker
