โJun-09-2016 03:02 PM
โJun-10-2016 07:30 PM
โJun-10-2016 07:09 PM
โJun-10-2016 06:26 PM
โJun-10-2016 06:19 PM
โJun-10-2016 05:57 PM
darsben1 wrote:
TO THE OP; CAN YOU INTRODUCE ME TO THE LADY IF YOU DECIDE NOT to buy?
For real ??? Where is SHotwell Park
I am on Shotwell Park
โJun-10-2016 04:58 PM
โJun-10-2016 02:21 PM
dicknellen wrote:
What model Itasca made by Winnebago is this. There is a build plate showing the model number and date it was built. I think you will find it by opening the drivers door. I have not heard of a Itasca Classic. Dick
โJun-10-2016 01:41 PM
โJun-10-2016 10:50 AM
โJun-10-2016 09:06 AM
โJun-10-2016 06:26 AM
โJun-09-2016 10:07 PM
luberhill wrote:toedtoes wrote:
We would actually need to know the age of the motorhome (not the lady ๐ ).
If it's an older MH, then it is quite likely that the water heater is propane only.
I'm assuming "fried" is supposed to be "fridge". Most likely that is correct - it will run off propane or electric (when connected to shore power or generator) but will not run off electric when not on shore power or generator.
"newer tires" is not saying anything. Check the code on the tires to see the actual age.
Would have to know the age of the MH to be able to guess if $29K is reasonable or not.
where are the codes" on the tires,,,and how do you read them ?? Thx
โJun-09-2016 08:47 PM
Harvard wrote:
If you put anti freeze in the WH it would take 6 gallons AND then you will have a tough time clearing the WH when you "summerize".
โJun-09-2016 08:09 PM
โJun-09-2016 07:18 PM
luberhill wrote:CharlesinGA wrote:
Snatch it up now unless it shows signs of leaking. Has it been under cover or out in the open?
What chassis is it on, Ford E350?
Charles
No signs of leaks,,,stored outside,,roof looks like one pc on rubber roof....that rear corner bed/couch may be a pain...
Under the bed is a thing that says "by pass"...she said that so you don't put antifreeze in the water heater....why wouldn't you ???
