โNov-18-2014 09:01 AM
โNov-25-2014 07:24 PM
donnie d wrote:
Good job on the troubleshooting. I also had a problem and used Good Sam road service. What a useless effort for $200.
โNov-25-2014 03:53 PM
โNov-25-2014 02:52 PM
โNov-25-2014 12:19 PM
โNov-23-2014 04:31 PM
YC 1 wrote:
Different coach but mine has a similar panel hidden with a plastic cover. It is not in my battery compartment. It would be very close to the starter in order to keep the wires as short as possible.
Once you find the relay you should be able to solve the problem in about two voltage measurements. Do yourself a favor and once you find it don't tug and pull on things to see if anything is loose. Takes some voltage measurements in case it is just a loose connection. Then you will have some facts. Better yet, take a digital picture and print it out. Then write on the picture your readings. Keep for future use. Don't rely on your memory.
โNov-23-2014 04:06 PM
โNov-23-2014 09:33 AM
โNov-23-2014 08:19 AM
โNov-21-2014 09:38 AM
FIRE UP wrote:
Glen,
I certainly don't mean to sound sarcastic but, it took four pages for someone to ask you what kind of coach, engine, chassis, and more. Many of the remedies that were suggested only apply to rigs with gas engines. Some applied to diesels. Now that you've stated your type of engine etc. Along with this post, I'm sending along a couple of pictures of the starting system on our coach. It's an '04 Itasca Horizon, 36GD with the C-7 330HP CAT.
Now, in those pics, you'll see the starting system relay and, remote mount solenoid. There's also a 100 amp fuse and, a secondary relay. All of which play a part in starting this beast. Now, here's a point. I have no idea if your DIESEL rig has anywhere near, the same type of system or not. If so, you'll need to find it and check it out. If not, well you can disregard this entire post.
But, our rig is 10 years old and, you'll see the kind of condition I found that starting system in, by accident when I was doing some other maintenance and repairs. So, while I had good access to it, I rebuilt it. But, your rig MAY have something very similar. Good luck.
Scott
โNov-21-2014 07:59 AM
โNov-21-2014 07:36 AM
Tinstar wrote:Tinstar wrote:
Exact problem I had about 2 1/2 months ago ANd it was the "other" relay that caused my problem. I had 12 volts from of the ignition but "0" at the starter. After a couple of days crawling around, I found an unlabeled relay. Put a known good on in it's place and my problems were over. That relay was in a bay near the back of the coach where my fuel filters were. It was hanging by wires on the back wall of a bay. Wiring went from ignition, to this relay to the starter. I was about to wire a remote switch on mine too and there's nothing wrong with doing that until you can trace it down.
Just a thought. I forgot to mention; The "other" relay I found controlled the 2nd solenoid that activates the starter. No juice was going through that relay to activate the 2nd solenoid that activates the starter solenoid. Hope that makes sense.
โNov-20-2014 11:59 AM
โNov-20-2014 03:17 AM
โNov-20-2014 02:22 AM
