help with electrical please
GGeorge
I have a 2014 Coachmen Encounter, I am sitting in Tacoma WA @ JBLM Holiday Park. I am plugged into a 50Amp shorepower. My front A/c, washer/dryer, fireplace, water heater, front tv and 4 power recepticles are working. My rear a/c, microwave, and refrig are not working along with 5 outlets. both bathrooms are working with electricity. I have checked for fuse blowout and all are ok. I have turned all fuses on and off. I have done the same with the "main". Currently my generator is in the shop and not connected. I have checked the GFI and it has been reset but was not triggered before the reset. ANY IDEAS????
G George
GGeorge
Marietta, Ohio
2010 Jeep Liberty
21 REPLIES 21
Artum_Snowbird
If you have your outlets listed in your electrical panel, see if all the not working appliances are on one side of your breaker panel and if all the working appliances are on the other side. That would tell you there is something wrong on one side.
Mike
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
downtheroad
2nd GFI.....maybe look at any outside outlets you have....or hidden in a storage bay.
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
enblethen
Do you have an energy management system in coach? Make sure it is set to 50 amp.
Reset shore power breaker.
Turn off all breakers in coach. Apply light pressure toward "off".
Turn on main breaker
Turn on branch breakers one at a time.
A/C units do not go through GFCI
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
GGeorge
my $450 surge protector says both lines are showing at least 118 thru 121.
GGeorge
Marietta, Ohio
2010 Jeep Liberty
donn0128
Check your pedistal power. It sounds like you have one leg dead.
GGeorge
any thoughts on where it will be. I have checked all recepticles I know of and I found only 1 in the half bath
GGeorge
Marietta, Ohio
2010 Jeep Liberty
Tom_N
You may have more than one GFI.
Sarver, PA/Crystal River, FL/Shelocta, PA · W3TLN · FMCA 335149 · Mystic Knights of the Sea
2005 Suncruiser 38R · W24 chassis, no chassis mods needed · 2013 Honda Accord EX-L · 2008 Honda Odyssey EX-L
